electrical problem
Old Jul 28, 2023 | 10:32 AM
J J N's Avatar
J J N
Cruising
Default electrical problem
I have a 69 coupe 300 hp a/c car. The problem I have is that when I try to adjust the dash lights or turn on the courtesy lights, the parking lights come on. If I turn down the courtesy lights the parking lights go off. Also the dash lights come on with the ignition switch. When I turn on the ignition the dash lights come on I can not adjust the dash lights with the headlight switch.. Any help will be greatly appreciated.
Old Jul 28, 2023 | 10:44 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie reply here:
Usually a loose ground wire under the dash causes these problems...the voltage goes to all the wrong bulbs.
If you have a tilt-tele steering column, some wires could be pinched inside the column.
Old Jul 29, 2023 | 06:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking I'd start at the headlight switch. Try jumping wires once switch is disconnected and see what happens. Then go from there.
Old Jul 29, 2023 | 10:52 AM
jpatrick62's Avatar
jpatrick62
For these types of electrical issues, I always look at the wiring diagram for help. Is there a common component that all the faulty circuits traverse? I don't have the diagram in front of me now, but as someone replied earlier, maybe the headlight swx would be a good place to start.
To electrical problem
