Solid Lifters
Old Aug 4, 2023 | 11:53 AM
Jon Wickstrom's Avatar
Jon Wickstrom
Default Solid Lifters
Good Morning Corvette Friends!
Has anyone known of 69 L46 to ever have had solid lifters? Mine is and early build November of 68.
Thanks,
Jon
Old Aug 4, 2023 | 12:26 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
1970, 1971, 1972 LT-1's had solid lifters, but i'm not aware of any 1969 small blocks to have them.
Regards
Roy
Old Aug 4, 2023 | 10:39 PM
n2h2o2's Avatar
n2h2o2
1969 Z28 with the 302 had solid lifters...L46 was hydraulic.
Old Aug 4, 2023 | 11:35 PM
Jon Wickstrom
I didn't think the 69 had solids, for some reason mine does. Pulled the VC's and the rocker arms are loose and adjusted like solids. My 350 is not #s matching. It looks like maybe a GM Replacemet # or it was rebuilt and someone stamped their own #. The block casting #s look like a 70 L46. Heads, intake and exhaust manifolds casting#s all match 69, 350/350 L46. ??
Old Aug 5, 2023 | 12:38 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hmm, 68 L79 327/350 is solids
would it be nice if the cam and heads were put on a 350 block.
Old Aug 5, 2023 | 05:58 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Let's just assume that in over 50 years someone has hotted up this engine just a tad.
Not numbers matching? Why would you expect anything else?
Old Aug 5, 2023 | 12:36 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
The 68 L79 did not come from the factory with solid lifters.
Old Aug 5, 2023 | 12:40 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
mine had them.
Old Aug 5, 2023 | 01:07 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
mine had them.
Unless you have owned yours since new, they were added at some point.
If they were on the 68 L79 I have not had to adjust mine in 38 years of owning it. The stock cam for the 68 L79 is GM 3863151.
Old Aug 5, 2023 | 02:30 PM
lynnbilodeau's Avatar
lynnbilodeau
Not an uncommon mod to make. I have a late 69 (October 1969 for the 69 MY) HW code L46 in my 69 Z/28 for now. Deck stamp is V1022HW. It has no partial VIN stamped anywhere, so could be the original engine to an L46 Corvette with vin between 732600 and 738762, or thereabouts.
I still have the original engine but didn't want to blow it up. I don't drive it often, but when I do, I drive it like I stole it.
I made some changes to the L46. I installed the 178 camshaft (70 LT-1) and used the intake and carb and distributor from my 302. Also have some high end small tube tuned headers from a company that is now out of business. It is a blast with 4.10 screw in the back.
No L46 came with solid lifters. The LT-1 camshaft is obviously uses solid lifters. Some time in the last 50 years, someone likely did something similar to your motor.
To Solid Lifters
