Sound proof.
Old Aug 6, 2023 | 08:22 PM
Golferdad's Avatar
Golferdad
Default Sound proof.
Boy this stuff,and a heat gun makes this so easy.
Old Aug 6, 2023 | 09:57 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You are going to be GLAD you took the time!
Old Aug 8, 2023 | 04:09 PM
Golferdad's Avatar
Golferdad
Yea,think I will try to pur some on the doors now.
Old Aug 8, 2023 | 09:10 PM
Golferdad's Avatar
Golferdad
Now,I have some left over so where are you installing it on the doors,I’m assuming between the door panel and door.and working around all the holes.
Old Aug 9, 2023 | 01:17 AM
Peterbuilt's Avatar
Peterbuilt
Default Wow!
You did an excellent job!
A lot of heat can come from the parking brake and shifter area so you might want to go there with the leftover stuff.
There should be a lower shifter boot, make sure it's good.
Old Aug 10, 2023 | 03:18 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
This is something I am considering, as much to reduce heat than noise. But, I don't want to spoil (and certainly not replace!) my nice, original carpets. Are the carpets stuck down, or just held in around the edges? If I can remove a side at a time carefully than I may look more seriously at some heat/sound deadening.....
Old Aug 10, 2023 | 09:28 AM
Driving69's Avatar
Driving69
On the door and as you mentioned, leave an opening for the hardware, linkage, drain holes and the lower access panel. A roller makes the job a whole lot easier.
Old Aug 12, 2023 | 09:02 PM
blueL48's Avatar
blueL48
i did the whole interior from top to bottom an front to back with kilmat and xmat from eastwood it has a added layer of closed cell foam. when i did the dual exhaust inside the car was like an echo chamber. now it’s nice an quiet. and a roller is recommended for proper insulation and was a huge help for me.
Old Aug 28, 2023 | 12:33 AM
SgtConner's Avatar
SgtConner
That looks AWESOME!
The sound proofing makes SUCH a difference. I just took mine for a drive after recently installing soundproofing. What a difference. Totally worth the effort!
To Sound proof.
