Indicators not working any ideas
Old Aug 15, 2023 | 04:04 PM
Lozofarabia's Avatar
Lozofarabia
Default Indicators not working any ideas
Hi all I've got a 1980 and I can't seem to find the indicator fault, they're not coming on at all however if the lights are turned on, the front stay on but they don't blink..
I've changed the blinker to an LEDs negative upgrade
Replaced the streering wheel indicator wiring
replace the complete rear light wiring
​​​​​​Is there anything else I can check or replace?
Any help would be grateful.
Old Aug 15, 2023 | 04:18 PM
Bikespace's Avatar
Bikespace
All LEDs? The front corner marker lights will screw you up. Also, the flasher base may need to swap orientation.
Here's my thread on how to make it work in my 80.
https://www.corvetteforum.com/forums...ispreloading=1
Old Aug 15, 2023 | 04:29 PM
Lozofarabia
I'll have a read though thanks, I've used standard and leds but I'm getting the same results, it seems there's a fault somewhere but I can't put my finger on it..
To Indicators not working any ideas
