My 78 fuel gauge has stopped working and now my low fuel light stays on all the time. Can someone tell me if this is an easy repair or something more involved? Thank you.
depends on what you call easy.
1. disconnect the gauge wire at the sending unit. Gauge should move to full pegged @ ~ 3 oclock.
2. Measure the ohms resistance of the sending unit. Range is ~ 1-90 ohms.
low ohms < 10 would indicate gas tank empty = gauge reads empty , low fuel light on. if it reads > 10 ohms then there is a short in the circuit from the wire to the gauge cluster. Could be fault in circuit or gauge.
The tank is full and the low fuel light stays on, all the time. Gauge is also stuck in the full location.
Still Measure the resistance of the sending unit. with full tank should read ~ 90 ohms.
Fuel gauge pegged overfull is usually a open circuit. Resistance > 100 ohms.
Low fuel light on thinks the resistance < 10 ohms. Possible low fuel board fault. You can remove the board and test again. (hard to get hands up there).
