82 crossfire Emissions
Old Aug 21, 2023 | 11:27 AM
Dwonch's Avatar
Dwonch
Cruising
Default 82 crossfire Emissions
Has anyone removed the smog pump and emissions on an 82 crossfire without any ecm issues. I don’t have a smog check where I live. Just trying to clean up the engine bay and make it easier to work on.
Thank You!
Old Aug 21, 2023 | 02:06 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Thank You!
You can removed it with no issues.
Old Aug 21, 2023 | 04:26 PM
Dwonch's Avatar
Dwonch
Cruising
thank you
Old Aug 21, 2023 | 07:15 PM
1860army's Avatar
1860army
Wait.. Aren't you the guy who has a fuel pump running all the time? Did you fix that...
60
Old Aug 21, 2023 | 07:33 PM
Dwonch's Avatar
Dwonch
Cruising
Default Re
60
Yes. I’m the same guy. I have not fixed it but I’m certain that someone has done some messing around with the wiring. I’m going to follow a diagram I found on the fuel pump wiring and see where he made changes. I also asked the question about getting rid of the smog junk. If it effects the ECM or any issues. I don’t have testing in my area.
Old Aug 16, 2024 | 03:11 PM
daleman's Avatar
daleman
Thank You!
Hi! Fellow 82 owner here. Did you remove the smog and if so, any issues?
To 82 crossfire Emissions
