Painted Mufflers?
Old Aug 25, 2023 | 11:51 AM
mbp's Avatar
mbp
Default Painted Mufflers?
Hello. I was told recently that the original mufflers on my 69 would of been painted a black color to sort of blend in and not stand out and be so obvious. Is this correct and does anyone have pictures of this done to any replacement mufflers? Just curious as to how it would look on the car. Take care.
Popular Reply
Aug 25, 2023, 04:52 PM
boat196's Avatar
boat196
I painted mine on my 1970
Old Aug 25, 2023 | 12:45 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's called "black out" and was applied pretty heavily by a spray gun. It helps to hide the mufflers from attention when the car is viewed from the back and through the wheel wells. I'm no expert on where on the mufflers they were sprayed but am pretty sure it was only the wheel and road sides.
Old Aug 25, 2023 | 04:52 PM
boat196's Avatar
boat196
Old Aug 25, 2023 | 05:38 PM
OldCarBum's Avatar
OldCarBum
Those look great!
Old Aug 25, 2023 | 11:14 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
That’s it exactly. It was done strictly for cosmetic purposes.
This was true for the 1963-1967 cars, but the 1968-1972 cars had the mufflers and a short section of the rear exhaust pipe completely painted, top and bottom. This was almost certainly done by the manufacturer (either Walker or Arvin). Afraid I don’t have knowledge as to what was done on the later cars.
Regards,
Stan Falenski
Old Aug 26, 2023 | 10:07 AM
mbp's Avatar
mbp
Thanks for the picture. What type and luster paint did you use? Looks good,I think you might of just made some work for me.
Old Aug 26, 2023 | 10:45 AM
DKM-106's Avatar
DKM-106
2024 C3 of the Year Winner - Unmodified
Regards,
Stan Falenski
Stan is correct. On 68-72 cars the top and bottom of the muffler was painted black form the manufacturer. An additional black out process was applied at the plant on the rear wheel well area and that is why you see a different type of black coating running down the outside of the muffler. Also, on original cars you may see the black out dripped on the rear suspension parts from the black out process at the St. Louis plant. Here is a paint I have used in the past that holds up really well;
Amazon Amazon
Here are a few examples of original mufflers with blackout
Old Aug 26, 2023 | 11:05 AM
boat196's Avatar
boat196
1618 High Heat
Old Aug 26, 2023 | 11:30 AM
jeffrey864's Avatar
jeffrey864
I painted my mufflers black like the factory with overspray. I use VHT SP 130 flat black. The mufflers does not get so hot as the exhaust manifold.
Old Aug 27, 2023 | 08:58 AM
Eliredandblack's Avatar
Eliredandblack
I have a 73 and read somewhere that the Chevrolet Plant assembly line workers applied the paint with gloves. The reason for the paint was to hide/blend the round mufflers with the spare tire holder. I believe the 74 had the oval shaped mufflers.
Old Aug 27, 2023 | 11:03 AM
Mdbirk's Avatar
Mdbirk
I used vht flat black.
Old Aug 27, 2023 | 12:49 PM
barkingrats
The glove idea was roundly debunked over on the NCRS forum. Just wouldn't be an efficient way for assembly workers to operate or the bean-counting use of materials. There are line photos of much of the Corvette plant and none show buckets of black out or gloves. Spraying would be much cleaner, quicker, and more material efficient. All of the paint coverage and drip patterning suggests spray application.
To Painted Mufflers?
