Horn not Working
Old Aug 30, 2023 | 12:19 PM
CanadianRover's Avatar
CanadianRover
Default Horn not Working
Having some fun with the horn on my '78. It worked well for years and then started sounding at will. I unplugged both horns to shut them off. When I got home I plugged them back in and all was well for a time but the problem recurred. I have power to the relay/key buzzer and I have power on all four terminals coming out. The horn button appears to be in good order. I have continuity from the horn button to the harmonica fitting at the base of the steering column, the test light indicates I have ground with the horn button pressed. Both horns sound when connected directly. Wire from horns to fire wall appears to be intact but I haven't checked continuity yet. Not sure if this (green) wire plugs into fitting on fire wall or not. Am I missing something?
