Why did GM develop vacuum actuated headlights?
That said, they aren't that difficult to bleed if you use the right procedure.
The same vacuum design used on numerous other cars GM put out
Yes, no other GM car had issues with water intrusion or rot. Must be why every single GM muscle car has perfect floor boards. Wait, no, that's one of the most common things to be rusted out...
GMs other offerings have positive camber under compression. To say nothing of how much the rear axle moves side-to-side on the A and F bodies. The Corvette's rear toe issues are incredibly minor in comparison.
No different than any other GM car.
Finally, one that doesn't apply to the other cars...
If you want access, buy a C10. Makes any muscle car look tight in comparison. In all honestly, this is drastically overblown. People like to bitch, but nothing about the C3 is that difficult, especially in comparison to modern cars.
Sounds like you need to work on your Corvettes. Mine is stupid reliable. Can sit for weeks, will start right up and drive anywhere I want it to. Works in triple digit temps, even if I don't care for it. Works long distances on freeways. Works in traffic to and from work. If yours doesn't, you need to work on it.
Think of tubing like wires and it makes more sense. To me, they're no big deal. Most C3's went decades w/o much trouble. Mine still work. I'm sure if Zora had an unlimited budget he would have done several things different. It's easy to look back and play barstool quarterback.
