Sidepipe insert mufflers
Old Sep 10, 2023 | 08:03 PM
Crider's Avatar
Crider
Default Sidepipe insert mufflers
My 68 came with 4" sidepipes with no baffles/mufflers in them. Needless to say it's far too loud. Which slip in mufflers out there are the quietest?
Old Sep 10, 2023 | 09:25 PM
Arg0413's Avatar
Arg0413
vette packs in mine, and i'm happy with them
Old Sep 11, 2023 | 12:02 AM
Bikespace's Avatar
Bikespace
The reverse-flow Hooker inserts are alleged to be among the quietest. You may as well stuff bananas in your sidepipes, though.
I think these might be them, but check the part number, and other reviews. You will take a performance hit with these.
Old Sep 11, 2023 | 10:51 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Years ago, I went with the STS Baffles in my Hooker sidepipes. Been very happy with them.
I even made the center pipe uncappable when I want more flow.
Old Sep 11, 2023 | 12:07 PM
Crimson Thunder's Avatar
Crimson Thunder
I second the STS baffles.
Old Sep 12, 2023 | 11:26 AM
MelWff's Avatar
MelWff
The quiet ones will also kill about 50 HP.
Old Sep 12, 2023 | 12:50 PM
commander_47's Avatar
commander_47
I'm with you on this. In my 383 with hooker long tube headers and side pipes, I opted for the Hooker baffles.
Being able to hear the radio and talk to my wife is pretty important. But that's just me.
Old Sep 12, 2023 | 01:26 PM
wwiiavfan's Avatar
wwiiavfan
Originally Posted by commander_47
Being able to talk to my wife is pretty important.
You must not have been married long.
Just kidding. Lol
No matter how much my wife complains, I’m not toning down the exhaust. Hell, I refuse to put on a passenger side mirror so she can’t “help” me drive from her side of the cabin. 😀
Old Sep 14, 2023 | 09:08 AM
commander_47
Just kidding. Lol
After 50 years of marriage my wife says she does not nag, merely offers "guidance".
I like the side mirror idea!!!!
sheeesh!!!
Old Sep 16, 2023 | 11:30 AM
Golfobsessed's Avatar
Golfobsessed
Just a question to those who have installed inserts. I have 4" Dougs ceramic pipes with Doug's 30" inserts.
Any insight on installing the inserts, i havent attempted yet as im still on the header part of the install but just setting the insert into the pipe appears it will be tight.
Is there allot of effort getting the inserts down the pipe, do I use a wooden dowel to hammer it down? I figure I can set the mounting brackets against something solid with a block of wood if I do have to hammer the insert in... anyone ever have to take material from the insert ends to make them fit?
I just don't want to get hamering and get stuck half way down and not be able to move the inserts in either direction.
Old Sep 16, 2023 | 11:56 AM
MelWff's Avatar
MelWff
It should be a snug fit. I typically place the header tube vertically resting on a piece of wood, braced against something or have someone hold it, and raise the insert above it and drop in letting the weight of the falling insert to carry it down into the tube.
Old Sep 16, 2023 | 12:01 PM
Golfobsessed
thanks MelWff, I haven't really put much effort but definitely not gonna just drop right in from the weight, I have some wooden dowels and will surely need to use them, nothing looks out of round so hoping they tap in fairly easy, waiting on replacement side tube from Summit supposed to be here today and need to finish drivers side header install.
Old Sep 16, 2023 | 12:04 PM
Bikespace's Avatar
Bikespace
Mine dropped right in. They were tapered (a big end and a small end) so direction mattered, but they were snug once installed.
Old Sep 16, 2023 | 12:20 PM
MelWff's Avatar
MelWff
Also beware there is an inlet and outlet end, so make sure they are installed in the correct direction.
Golfobsessed
Thanks gentlemen... the inserts are marked "inlet" and "outlet"
I actually just took a little bit of 80 grit on a DA and took some of the burrs off the outlet end of the insert and it is sliding in... again thanks guys
Old Sep 16, 2023 | 12:21 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree. Although not a Corvette, I had the Hooker sidepipes on a 1977 Pontiac T/A that I owned back then (Hooker made then for a number of GM cars, not just 'Vettes, back then) Installing the sidepipes on a car that originally came equipped with a single exhaust, choked down by one of the "old style" catalytic converters, made a huge difference in the performance....like night and day. However, I initially used the "glasspack" inserts, and after a summer of driving with them, I got a little tired of the noise level.
I removed them, and installed a pair of the "reverse flow" inserts, and while they brought the sound level down to something more acceptable, their flow restriction did make a noticeable difference in performance.
Old Sep 16, 2023 | 12:35 PM
Golfobsessed
I'm installing the glass pack (mid level) inserts but also got the higher flow... with the sock L48 I'm not too concerned yet... i do believe this will be the noise level im looking for, i will see about any performance hindering before make a decision on the highr flow, my thoughts are I'm gonna lean towards the mid level which is why I'm doing those first
To Sidepipe insert mufflers
Old Sep 16, 2023 | 08:09 PM
wwiiavfan's Avatar
wwiiavfan
They should drop right in. Do like the Classic Chambered inserts - they have 3 or 4 small longitudinal cuts in each end, on the bell. You bend the metal outward slightly at the cuts so it automatically sizes itself to your pipe when you push the insert in. Presto, no rattling or moving around.
Old Sep 16, 2023 | 08:12 PM
Crider's Avatar
Crider
Been keeping up with the replies on this thread. I think I'll go with the STS baffles. Any suggestions on the best place to purchase them?
Old Sep 16, 2023 | 08:16 PM
MelWff's Avatar
MelWff
Where have you seen a place other than below to buy them?
https://www.spiralturbobaffles.com/
