Universal AC Compressor
Old Sep 14, 2023 | 06:58 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
Default Universal AC Compressor
Helping a buddy with an 82. AC original car but needs new compressor. Found a highly rated sanden style universal compressor. I’m willing to fabricate mounting brackets. Has anyone done this before? What else is needed for it to work with the rest of the stock components?
Old Sep 14, 2023 | 08:35 PM
n2h2o2's Avatar
n2h2o2
My 2 cents...
The cost of a correct AC compressor is probably cheaper than any universal set up after all the time & frustration is factored in...
Old Sep 15, 2023 | 10:00 AM
Tampa Jerry's Avatar
Tampa Jerry
Sanden compressors work very well with R-12 and R-134A, just be mindful of the oil. Also, many companies make mounts for the Sanden, try Vintage Air or Classic Auto Air. I have seen mounts for large and small block in right and left applications. Jerry
Old Sep 16, 2023 | 03:02 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
I sent you an email
Dan
Old Sep 21, 2023 | 09:01 AM
Bluesting70
Originally Posted by 0311 jarhead
I sent you an email
Dan
thank you. Very helpful
Old Sep 21, 2023 | 02:13 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
To use that compressor, you will need to do it right, the following...
Sanden compressor: 21-4536
Bracket for compressor: 40-113R
Orifice tube
Condenser: 11-31930
Binary safety switch: 24-0102
Step fitting (need to know which one you need)
Accumulator: 21-1248
AC Hose kit: 51-1034
AC Hose: 95-0449
This will allow you to retain the factory 82 AC in-console control panel. Old Air Products, very helpful, talk with Joe ext: 115
Old Sep 22, 2023 | 11:51 AM
Bluesting70
Orifice tube
Condenser: 11-31930
AC Hose: 95-0449
thank you for taking the time to give me this.
To Universal AC Compressor
