Rear ride height measurement requested
On a fully assembled car?
I am building my suspension in bare frame mode.
(Please include your rear fender height and tire size.)
Mine seems very close:
Is 1.75" here really correct?
snubber to what part of the trailing arms? And it would have to be much, much greater than what your asking about.
How do you wish it measured?
you want a measurement from the bump stop to the trailing arm! Not the snubber which is the forward diff mount. Thus my confusion.
with my car hanging on jackstands waiting for parts from the states this I can not get at the moment.
FROM THE BUMP STOP. TO THE TRAILING ARM!
I set my strut rods according to the factory AIM "D" measurement of 2.1" and I only get 1.75" here. But I do have 2 mods that are probably messing me up. The lowered diff crossmember with the VS bushings, and the VS smart strut bracket. Both of these mess up the "D" height and I am having a hard time compensating, and coming up with a measurement that makes sense. 1.75" clearance on bumps just does not make sense to me!
Plus my QA-1 shocks are going to bottom out (with no more travel) 1/8" before the T/A arm hits the bump stop! WT*!
I'll change strut bracket back out today and do some more measuring.....
The AIM says the rear "D" height should be 2.1" with no-passengers. How can this be if there is only 1.75" of suspension travel? Confused.... And over on the right it says there is 3.5" of Ride Travel on Jounce?????????
The little v-block is 1-3/8" in this axis
Just slides in under the rubber pad with a very slight interference, the pad is pretty soft still
Fender height 27-3/4"ish
Conti 235/55 17" which they say is 27.2" tall
M
Thanks!
Yours is almost dead-on the factory measurements too.
It is just a lot less clearance than I was expecting.....
Those bump stops must hit occasionaly......
My 1/2 shafts are pretty close to level when sitting
Honestly it should probably come up a bit as the ground clearance isn't very forgiving.
M
