Custom Console Data Plate
Old Oct 25, 2023 | 11:37 AM
Corvette-ZL1's Avatar
Corvette-ZL1
Default Custom Console Data Plate
Hi members,
I've been reading other forum threads about custom console data plates, and I'd prefer to do the custom lettering myself. I'm not interested in the '3 window' blank data plates that you can buy. I want to use the '4 window' data plate like you see on the 68-72 Corvettes. I have a spare one that I can wipe the current numbers away, but want to replace the values that reflect the displacement, compression, HP, and TQ ratings of the BPE stroker that I'm going to put in.
Ignatz did something like I would like to do, but where do you get the sticky sided clear lettering? The shop willing to silkscreen this is pretty far away, and they aren't open on weekends, so it's a logistical challenge to get to them, and I don't mind doing this myself if someone can provide specifics on how they printed the lettering or where they bought it if they did not make the lettering themselves.
I have never done anything like this before, so I don't even know where you'd get the one-sided clear printing paper that you can throw your average everyday printer. I suppose Kinkos could do it, if that the best way, but open to alternatives, along with specifics on how you create these numbers and the materials involved.
This is what I refer to as the '4 window' console plate. I have a spare one of these, and want to use this as my template. I intend to only wipe the numerical values clean and replace with the ratings for my new stroker motor. Thanks to C3 Stroker for the image of his shift console!
This is what I refer to as the '3 window' console plate that you find on the post-'72 C3 corvettes.
Old Oct 25, 2023 | 12:48 PM
Coronette's Avatar
Coronette
As the original is printed metal and not paper, if I were looking to do what you are, I’d take some exemplar photos to a reputable print shop and see what they can come up with. They can print on silvery metal with an adhesive, can match the font, etc.
One of my after school high school jobs was working in a print shop, so I enjoy taking projects to print shops. Some things are better done professionally than DIY.
This is a blow up of a photo from mine, so image quality isn’t the best.
Good luck! Post it when you’re done!
1969
Old Oct 25, 2023 | 01:41 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by Corvette-ZL1
Hi members,
FYI: 68' does NOT have a data plate
Old Oct 25, 2023 | 01:57 PM
Corvette-ZL1
My bad.... Thanks for the correction, but I'm really looking for specific information on how to edit my console data plate for my '69 from folks who have done it themselves.
Old Oct 25, 2023 | 03:27 PM
C3 Stroker's Avatar
C3 Stroker
Sticky sided labels are available from Avery. https://www.avery.com/products/labels/27952
You can print what you want in your font and cut to size.
Old Oct 25, 2023 | 04:17 PM
Corvette-ZL1
Ah Perfect. Thanks C3!
Old Oct 26, 2023 | 09:22 AM
HeadsU.P.'s Avatar
HeadsU.P.
I bought a somewhat blank data plate from a Vette vendor because the stock H.P. data was too modest for me.
Take a look on Amazon for a "Label Maker". You can adjust the font, size of letters and script style. Handy for labeling toolboxes, etc.
The label itself is a roll of tape. That come in white, green, red, yellow and CLEAR, which is what you want. Clear with black letters / numbers.
You can print out sample sizes to check for fit on the engine data plate. Once the correct size label is created, it's just a matter of peeling off the backing and applying.
It leaves no curled edges or wrinkles. Looks factory, but custom made.
Old Oct 26, 2023 | 11:40 AM
Corvette-ZL1
This is awesome info. Checking it out. Thanks HU!
Old Oct 26, 2023 | 12:48 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have a Brother unit. Model PT 2030.
Then you buy the cartridges separate.
Old Feb 15, 2024 | 04:44 PM
Lifted_horns_4x4's Avatar
Lifted_horns_4x4
Cruising
Do you have a link to the labelmaker you bought?
Old Feb 15, 2024 | 07:40 PM
HeadsU.P.'s Avatar
HeadsU.P.
No I do not.
It's a white table-top machine, 120V w/ adapter. Has a mini keyboard and several fonts to choose from, plus letter sizing.
The cartridges come in 3 or 4 colors, clear, white. But you will want clear w/ black lettering.
The cartridges have a spool of the tape, self sticking. Great for custom made, engine data plates
Might try Amazon, Brother Label Maker. Model PT 2030
Old Feb 27, 2024 | 01:31 PM
Lifted_horns_4x4
Cruising
Default label size
Hi members,
Do you know what size of label width you used? 1/4" or 3/8" or 1/2" or 3/4" or 1"
Old Feb 27, 2024 | 01:33 PM
Lifted_horns_4x4
Cruising
Default label size width
No I do not.
Do you know what size of label width is best? 1/4" or 3/8" or 1/2" or 3/4" or 1"
Old Feb 27, 2024 | 02:24 PM
HeadsU.P.'s Avatar
HeadsU.P.
Looking at my "Clear" Brother cartridge it says 0.70 width. That seems wide to me, but it must be close to 3/4".
Keep in mind, that's the tape or label size. The machine can set any size of font you desire.
If the tape seems too wide, you can always trim away with common scissors.
The hard part is determining the length of your word to fit inside the data plate box or window. It may take a few practice runs to perfect it.
Once the labels are installed, there is not a curled edge showing. So it looks professional or factory.
Old Feb 27, 2024 | 02:56 PM
ZIOGEO's Avatar
ZIOGEO
Is the blank plate made from aluminum?
Old Feb 27, 2024 | 04:33 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
A few examples:
Someone bought a bunch of OEM plates:
Old Feb 27, 2024 | 08:45 PM
Mooser's Avatar
Mooser
For what it's worth
I used 2x4 Avery 7663 clear laser labels
The font was NimbusSan Regu
460 was 32pt 100% tall and 53% narrow (skinny)
CUBIC INCH was 10pt, 125% tall and 90% wide, 14pt spacing between the lines
Torque/comp was 10pt, 130% tall and 90% wide, .222 between the two lines of text
M
To Custom Console Data Plate
Old Oct 11, 2024 | 02:18 PM
Jetglow's Avatar
Jetglow
Made with a process for metal called sublimation…. Had my local sign store make them for me for $20 each.
they took raw aluminum and made them…. I did not buy blanks… rather had them made…
Old Oct 11, 2024 | 02:39 PM
C3 Stroker's Avatar
C3 Stroker
Those look fantastic!
Old Oct 11, 2024 | 07:26 PM
427SIXPACK's Avatar
427SIXPACK
LQQKS, great !!! That appears to be a hell of a lot of work for only $20 .............. * B A R G I N * !!!
