I dare you...
Old Oct 26, 2023 | 07:48 PM
kanvasman's Avatar
kanvasman
Default I dare you...
I dare anyone to come up with a worse project in a '78. Replacing the cheap plastic rear window trim clips. Whoever that engineer was should have to do this job 3 or 4 times. Car is a project and I am finally getting some serious things finished up. I needed to replace some of the clips around the rear window and after much searching, and thinking, and waking up at 3 in the morning I admitted the fact that you have to pull the window. Pull a potentially $1400 window to replace $30 worth of lips. I had an guy... really, had a guy who installed a front windshield at my house for $250 a few months ago. I asked him to come and pull the rear window so I could do the new clips and then put it back in. I was practically begging him but no go. I guess he was afraid he might break the window. I told him I expected that to happen and it would be on me, but he still wouldn't do it. SO today I pulled it out and began the cleanup. !/3 finished. Now I just have to clean the glass and put it back in without breaking it. Where is that engineer...
Old Oct 26, 2023 | 08:03 PM
RickM Z06's Avatar
RickM Z06
Maybe. That is something I haven't had to do on my 78. But, replacing the heater core, evaporator or blower motor, has to be right up there.
Old Oct 27, 2023 | 08:30 AM
kanvasman's Avatar
kanvasman
Agree with that project. When I did mine the motor AND dash were out. Not too difficult doing it that way. I just can’t understand why another design wasn’t considered. But I guess this is only a problem from 78 to 81 so no one worried about it.
Old Oct 27, 2023 | 10:10 AM
ukjohn's Avatar
ukjohn
Depends on exactly where your clips are in relation to the glass. I managed to replace 5 of mine without removing the glass, wasn't too difficult.
Old Oct 27, 2023 | 10:29 AM
kanvasman's Avatar
kanvasman
I could have done a few of them with the glass in place. Some of them I could get out but could not put the new ones in place. I thought about mixing u.p some epoxy but didn’t want to take a chance of it not holding. This has been a long time project and I am about to start putting carpet in and my experience has been that there is always time to do it right (any job) the SECOND time. And now I can put the carpet and the rest of the back together with the window out, which will make my old aching back happy.
Old Oct 27, 2023 | 12:21 PM
ukjohn's Avatar
ukjohn
Yes I was lucky, there was just enough room to get to the ones that had broken, I couldn't have got to a lot of the others.
Old Oct 27, 2023 | 01:15 PM
OldCarBum's Avatar
OldCarBum
Try getting the rear window defroster motor out of a 73.
Lots of four letter words go flying around with that one.
I might have even come up with some really bad five letter words!
Old Oct 27, 2023 | 01:43 PM
Tranz Zam's Avatar
Tranz Zam
I pulled the rear glass off my 78 to install new clips, then re-installed with butyl tape. Wasn't that difficult. The glass is much stronger than you think. The delicate glass is the windshield.
Old Oct 27, 2023 | 06:21 PM
kanvasman's Avatar
kanvasman
The rear glass is pretty stout. I have the butyl tape coming next week. I am.actually lookin* forward o putting the sunshade back in and getting some speaker brackets made up while standing up before I lay down the carpet and then getting a helper to help me lift it up.
Old Oct 28, 2023 | 06:09 PM
loup68's Avatar
loup68
Army
Good luck with it, Jim. Lou.
Old Oct 28, 2023 | 06:14 PM
interpon's Avatar
interpon
I want to remove the rear trim on mine..heard horror stories..
how did yours break?
Be great to see how and document they are fixed with glass though in and or out?
good luck!
Old Oct 30, 2023 | 08:15 AM
dtamustang's Avatar
dtamustang
the window does not need to be removed to change the clips , on the two bubblebacks i painted all the clips were changed with the window in place. over the years i have changed broken clips on several others. it can be a challenge but its doable. early on i decided hell would freeze before i would pull the window to change them and figured out a way to do it. i put a how to video on my old facebook page. the page is long gone but if the video survived a computer crash i'll put it up here
Old Oct 30, 2023 | 08:28 AM
kanvasman's Avatar
kanvasman
Thanks for all your support. The clips broke because they were old and brittle. Tries a few different types of tools but by, th time I got the trim off bout a third of them had snapped. And I did manage to get a few out but on the bottom edge ( where most of them had broken) there was only about 1/4” clearance between the window and the car. On the top edge there was about 1/2”. Rather than spend a lot of time replacing the broken ones, while all the time worrying about breaking the rest when putting the trim back ( after a paint job) I thought it would be best to tackle it all at once. And Lou, thanks, I need all the luck I can get. Butyl tape scheduled to arrive tomorrow, got to finish making up some speaker enclosures ( this is so easy being able to actually stand upwhile making a template) then we go for the glass.
To I dare you...
