Engine bay painting
Old Nov 22, 2023 | 09:53 AM
jm1gic's Avatar
jm1gic
Default Engine bay painting
My 350 is pulled, so figured now was the time to clean up the engine bay and do a bit of painting in there. Anybody have experience with it? Is there a special paint? Anything I shouldn’t paint?
Old Nov 22, 2023 | 10:05 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
As for paint, I like SEM Trim Black (#39143). It's a medium sheen black that is close to factory. As to what not to paint, generally, if it's not attached to the firewall or inner wheel wells with a rivet then don't paint it.
What year is your car?
Old Nov 22, 2023 | 10:24 AM
SEVNT6's Avatar
SEVNT6
I used Dupli-Color engine enamel on everything. Low gloss black, orange, silver. Filled & smoothed the firewall.
I also added a little chrome along the way....
STA70972
STA70981
Old Nov 22, 2023 | 01:05 PM
hunt4cleanair's Avatar
hunt4cleanair
I used aluminum foil to "mask" items that did not require either spray or overspray.
Old Nov 22, 2023 | 01:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Actually there is a special paint........a lot of different suppliers make it but it is basically called "Chassis Black" by most.......the GM # was 10150104...but IDK if it is still around...looks discontinued.....
Anyway.....it is a spray out of the container paint, requires a gun.......cheap $50 spray gun is fine......shoot it on and wait a day...takes forever to dry, but is a perfect satin black finish....and super durable.
Jebby
Old Nov 22, 2023 | 02:17 PM
Kidster71's Avatar
Kidster71
Highway Man
Highlights I got from the threads below:
  • Semi-flat or satin black for firewall and under body paint.
  • Semi-gloss should be used for bolt on components and brackets.
  • Wiper bay is semi-flat/satin black [blackout] paint.
I ended up using John Deere Blitz Black Paint - TY25631 for firewall and under body paint.
https://www.corvetteforum.com/forums...ngine-bay.html
https://www.corvetteforum.com/forums...mpartment.html
https://www.corvetteforum.com/forums...ent-paint.html
Cheers,
Richard
Old Nov 22, 2023 | 03:58 PM
Tuna Joe's Avatar
Tuna Joe
Jebby
It was available on Amazon in a gallon. I paid about $100.
I use the $15 Harbor freight gun that’s purple.
good stuff!
To Engine bay painting
