77 Fuel lines
Old Nov 26, 2023 | 09:05 PM
urbnasty's Avatar
urbnasty
Navigator
Default 77 Fuel lines
Anybody have some tips for routing preformed fuel lines on a 77 with the body lifted off the frame a few inches. I'm replacing all the body mounts and trying to rout the fuel lines.
Old Nov 26, 2023 | 09:42 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If you have the body up, should be easy.
Old Nov 27, 2023 | 09:40 AM
jpatrick62's Avatar
jpatrick62
I have the same issue: have to replace the main and return fuel lines on a 69. The big question is can you replace both with preformed lines if the body is lifted maybe 4 inches off the frame? If I do this I will photo the process for others, but really questioning whether the process can be done just lifting 3-4 inches off the frame..
Old Feb 27, 2024 | 03:00 PM
urbnasty's Avatar
urbnasty
Navigator
I did it but it was a pain the rear.
To 77 Fuel lines
