73 Vet automatic to 4 speed conversion
I have been unable to find the retainer which rivets to the fiberglass on the underside of the tunnel for a four speed. The opening is obviously smaller for this retainer than for the automatic the only part number you can find is for the automatic and most supply houses show it’s the same for the four-speed as for the automatic, but as presented in this picture, it is obviously not
This is the part number that I cannot find which would allow me to install the floor boot and upper retainer for the four-speed shifter
ur speed. Is there a conversion piece that is made to allow the four speed, shifter components, boots, and retainers to fit, the larger hole in the tunnel for the automatic car
most suppliers list the four-speed part number incorrectly for an automatic part. Read their description, it says, automatic, not for speed, and if you look at the assembly manual, the opening for the automatic is more than 1 inch larger than the four speed.
