Rubbery Adhesive in windshield frame
It was obviously there in 1976 when I bought the car from the original owner and I have never replaced the windshield or any of the trim parts. After all this time it was still pliable, hadn't hardened and stuck tightly to both the windshield frame and the underside of the molding. Was this normal and part of the manufacturing process and if so, what was the black adhesive so I can fill the cavities when I install the moldings on the new windshield frame?
Thanks.
This is the stuff.
I still prefer it to urethane on these old cars.
New cars use polyurethane that holds like nothing else out there...But you would destroy the windshield and probably rip your birdcage out trying to replace a windshield in the future.
https://www.ecklers.com/windshield-o...E&gclsrc=aw.ds
I use the tape as a dam on the windshield inside edge of the frame and then apply butyl in a caulk gun outside of that.
So when you look through the windshield you can only see black. After the windshield is installed, I use the caulk gun to go around it and also to seal the stainless trims...
The cars will never see rain again most likely anyway.
Don't need to make them water proof to 30 meters as if it's a submarine...lol
But the question was, what is used under those upper chrome plated corner sections.
I rebuilt my entire roof and windshield frame about 3 years ago. I was then asking the same question.
And the answer is still 3M strip caulk.
Reveal Molding-Roof Center Support & Upper Windshield UPC 1 ASM Sheet F11.
Shows 155 Sealer and 194 Cement
Cements and Sealers are on UPC 0 Sheet D-3 to Sheet D-6
UPC 0 Sheet D-3 for 155 sealer details
UPC 0 Sheet D-5 for 194 Cement details
Here is a good thread from one of the CF Gurus, Alan 71
https://www.corvetteforum.com/forums...r-molding.html
Cheers,
Richard
Super knowledgeable, friendly "CAR" guy !
Click here >>>>> https://fontanas-auto-glass-inc.business.site/
My '72 is in a similar state regarding the caulking/sealant at the chrome joints. If you read the water testing specs in the AIM, it's a pretty good soaking they had to endure with no leaks. 30 nozzles placed at most a foot or two from the surface, each spraying water at a minimum of 3 gallons per minute for at least 4 minutes. Better to over apply the caulk than send the car back for remedial work.
"3M Strip Caulk" are flat strips of butyl
The windshields were originally set into a round (or oval) butyl bead that was installed on the inside edge of windshield frame.
You can see this in the AIM.
There was also an additional bedding sealant that also appears to be a butyl product. This is NOT shown on the AIM diagram.
However, when you pull out original windshields and trim you see this sealant the OP describes. It is a bedding sealant for the windshield.
It is butyl caulk.
This bedding sealant is important for windshield install because you can look through the windshield and see the bedding and the seal.
This same bedding sealant was used to install and seal the stainless trim.
These are the closest to the original seal and bedding sealant I could find.
Butyl caulk is extremely messy but cleans up very easily with, (and dissolves in) acetone.
I don't like these NEW materials.
They were made to glue glass to a car and becomes part of the structural integrity of the car.
C3's weren't designed this way.
But the install procedure is the same principle. The round butyl ribbon is applied to the frame and then a caulk bedding is applied to seal the windshield...
The 3M strip caulk is less messy than in a tube, so some might prefer it...
But butyl caulk from a gun is really messy...It gets on everything and sticks to everything...
But, like I said, acetone makes it an easy clean up.
I use a lot of the caulk under the trim and use a rag soaked with acetone to remove the excess and smooth it out nicely.
