Trailing Arms
Old Feb 10, 2024 | 11:59 AM
CHRISTOPHER PRIZGINT's Avatar
Default Trailing Arms
Default Trailing Arms My 77 is being done by a shop. I want to put in offset arms. Can I buy offset arms without the rotors but everything else? I am having the Wilwood kit installed so not needed. Also looking for advice on front suspension. Rear is just getting fiberglass spring and new shocks. Thanks
Old Feb 10, 2024 | 02:36 PM
69L88's Avatar
69L88
Yes, you can buy just the offset arms. Several suppliers.
Why are you needing to make the swap from stock?
Old Feb 10, 2024 | 02:49 PM
ignatz's Avatar
ignatz
I would recommend whoever you get them from has full compliance bushing (i.e. Heim joint or similar).
Old Feb 10, 2024 | 06:18 PM
I want to run a bigger tire. I keep reading I can run it by just moving the e brake. The suspension will all be new so I was figuring why not make sure that is new and let's me run the bigger tire.
Old Feb 10, 2024 | 06:56 PM
69L88's Avatar
69L88
Not sure what size tire you are thinking about but I’ve run 28x12s on 15x10 rims with a 5” backspace with stock arms for 51 years, including retaining the original location for the small bracket for the emergency brake. That said, moving that bracket is a very simple job. Certainly your decision but just wanted to let you know you might avoid having to drop $1500 on a pair of arms.
To Trailing Arms
