71 corvette electrical
Old Feb 24, 2024 | 11:30 PM
jm1gic's Avatar
jm1gic
Default 71 corvette electrical
Here is a dumb question with hopefully a nice and simple solution. No engine currently in the car, but I figured I could use this time to check my electrical. How do I get power to the car? To see what does and doesn’t work?
thanks!
Old Feb 24, 2024 | 11:50 PM
Bikespace's Avatar
Bikespace
Read this cautionary tale:
https://www.corvetteforum.com/forums...er-wiring.html
And consult a wiring diagram:
https://wordpress.keystonestatecorve...m/?page_id=118
Then determine what you need. A starter, properly grounded to the chassis, and wired correctly, should be a suitable substitute for a complete engine, if you don't crosswire anything. A power supply (current limited) is safer than a battery for initial hookup.
Old Feb 25, 2024 | 01:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The wires that connect to the large terminal of the starter solenoid would need to be joined together. Then install battery. Away you go!
Old Feb 25, 2024 | 01:55 AM
socal_tom's Avatar
socal_tom
I liked that answer 4-vette down and dirty quick and simple BAM there ya go
Old Feb 25, 2024 | 07:45 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
ya, its not rocket surgery. The key will still control the power that is going inside the cabin. The power going to the alternator and the horn relay will still be live.
Old Feb 25, 2024 | 07:55 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
thanks!
engine only supplies power running, not running, battery.
worries me because many hot wires connect to engine and with engine out those wires are hanging loose.
get a wire diagram to find and identify these wires
Old Feb 25, 2024 | 08:01 PM
Rescue Rogers
What hot wires...coil, and.......already mentioned alternator so theres 2. Just put tape on them, dont put them in your mouth. I have to say that since you kids like to eat Tide Pods and we have to remind you of these things in todays world.
Old Feb 25, 2024 | 08:10 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
What hot wires...coil, and.......already mentioned alternator so theres 2. Just put tape on them, dont ut them in your mouth. I have to say that sonce you kids like to eat Tide Pods and we have to remind you of these things in todays world.
To 71 corvette electrical
