Help with unknown wiring connector
Old Feb 25, 2024 | 04:59 AM
Aussie79vette's Avatar
Aussie79vette
Default Help with unknown wiring connector
Hi Guys, I am doing the wiring in my 69 and trying to find were all the wiring goes under the dash, have sorted all but one connection.
This one looks like it should go near the heater box as the length of the wire is long and bent like its been made to go in the same
direction as the flasher wire/connection.
Not sure if the fuse holder is factory or after market
Old Feb 25, 2024 | 05:46 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Fuse holder definitely not stock. Yellow, purple, brown.
I don't have a 69, so best quess. Wiper switch.
Old Feb 25, 2024 | 07:38 AM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
My 69 has nothing like that. Nothing I have run into anyway. Not the wiper switch. Good luck
Old Feb 25, 2024 | 07:40 AM
sw69vette's Avatar
sw69vette
I could be wrong but it looks like its for the blower resister which is on the back of the heater box .
Steven
Old Feb 25, 2024 | 07:53 AM
Catfish4818's Avatar
Catfish4818
Rear window defogger.
Old Feb 25, 2024 | 08:21 AM
robertea's Avatar
robertea
I have been working on an updated 69 Wiring Diagram, so I am interested in where that connector goes. I does not appear in GM's wiring diagram, but GM did not show wiring for options in their diagram, plus GM made many errors in their wiring diagram and it has taken a long time to find most of them. Your wires appear to be yellow, purple and brown or tan, which does not show up in the standard wiring. The heater resistor would be yellow, lt.Blue and orange, the wiper switch would be dk blue, lt blue and black/white.
The previous suggestion was the rear window defogger. Being an option that would not be in the GM wiring diagram. I have been working with a couple of other guys on the Forum so that I can release an updated version of my diagram and have been trying to find the wiring on options that GM never showed. If/When you find out where it goes, please post it so that I can include it in my drawing. I was planning to post it sometime next week.
Old Feb 25, 2024 | 08:25 AM
Catfish4818
My guess as to why Aussie doesn't see where it goes, is because with the interior disassembled to do that work, the forward console extension, with the switch installed in it, is in a pile of parts somewhere outside the car.
Old Feb 25, 2024 | 09:13 AM
Aussie79vette
Thanks for your replies, yes I have the option of the rear demister, will get the centre console extension and see if it fits the switch.
Hopefully that's the place it goes
Andy
Old Feb 25, 2024 | 09:28 AM
'73and'75's Avatar
'73and'75
Aussie79vette, that connector is for the optional C-50 Rear Window Defogger.
OP's wire colors at the connector are yellow, tan, and purple., with the in-line glass fuse holder attached to the yellow wire.
See my post #10 in the link to the thread below:
https://www.corvetteforum.com/forums...ment-75-a.html
Those pictures are from a 1975 C-50 Rear Window Defogger wiring harness, but the wire colors (yellow, tan, purple) are the same as the OP's. The connector is different for 1969's because the switch is different. 1968-1973 used a 3-position **** that was rotated, 1974-1975 used a 3-position rocker switch.
The wiring terminates at the switch, which is mounted to the drivers side forward console extension panel. Switch shown is from a 1970.
Old Feb 25, 2024 | 07:54 PM
Blue73Shark's Avatar
Blue73Shark
Attached picture shows the same connector that connects to the rear window defogger (round **** switch type) in my stock, orginal 1973.
Fran
To Help with unknown wiring connector
