Can you identify any of these brackets?
Bottom two are nose support brackets that bolt to the front of the each fender skirt and attach to the nose support steel channel located just behind the headlight openings. There is a flat steel plate inside/wheel side of each fender skirt that is a backer to these two brackets. Install two bolts through the fender skirt & steel plate to the nose support bracket and one bolt from the nose support bracket to the nose support channel. Hope this helps.
2nd row down from top are the brackets that mount the plastic grilles in the nose if I recall correctly. (the grilles with the parking lights/turn signals)
A couple more or closer pictures would have helped as well as the year, but I think the following list is correct.
Top left is a 75-79 inner grill bracket. I can't tell from the picture if that's a left or right, but there should two inner grill brackets.
The top right looks like a 73-76 right side upper fan shroud bracket.
As SLVRSHRK correctly pointed out the two in the second row are 75-79 outer grill brackets.
As BKarol said the one second from the bottom is the 76-79 front exhaust hanger bracket that gets attached to the transmission mount.
As Jerry71 said the bottom two are 69-82 outer front surround reinforcement to inner fender skirt supports.
