1969 C3 Horn Mounting Points
Old Mar 14, 2024 | 09:27 PM
cayoung's Avatar
cayoung
Cruising
Default 1969 C3 Horn Mounting Points
My 69 C3 only has one horn mounting point with nut inside front structure on left side. Where is my other horn supposed to mount? Did the factory screw up and mount both on the same bolt? Has anyone drilled a hole to front structure for a large screw? Metal seems pretty thin without the nut built in behind so would have to add a rivnut or just put both horns on one bolt.
Old Mar 15, 2024 | 01:14 PM
robertea's Avatar
robertea
All of the 69's should have come with two horns, mounted just over the center of the metal brace. Here is how mine are mounted and also a part of the AIM showing the horns.
Old Mar 15, 2024 | 01:34 PM
cayoung's Avatar
cayoung
Cruising
Not on mine. See photo.
To 1969 C3 Horn Mounting Points
