Brake booster/master question
Old Mar 22, 2024 | 04:20 PM
TotalC71's Avatar
TotalC71
7th Gear
Default Brake booster/master question
So, after tearing my 71 apart many years ago. I ended up tossing the master cylinder, figuring the PO screwed it up anyway.
I am now rebuilding and read information that I am unsure of.
I purchased a 1971 master cylinder, but after reading info from another source, discovered my booster has the recessed mounting point ( I believe that means its 76 or later ).
Can I use the master cylinder that I have, with this booster, or do I need to get a newer Master Cylinder.
I also have no push rod, so would just ensuring the rod length is correct be OK with this Mater Cylinder?
I have a measuring tool, then realized I was missing the rod ( this is what happens when you tear a car apart, then move into a different house )
Old Mar 22, 2024 | 06:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Check the site you bought the master c. from. They may have a list that shows the years the master c. will fit.
