Shocks
Old Mar 28, 2024 | 06:04 PM
pete315's Avatar
pete315
Default Shocks
I just put the 81 on the road today. Rides real hard. This car sat for a while and the shocks look original along with a lot of other parts on this car. I just changed the original ignition wires which made a huge difference. Question- Has anyone used Monroe Spectrum shocks or the cheaper Gabriel Ultra shocks? I'm actually looking for a softer ride. I just checked my air pressure in tires and all 4 were 36 psi which is way too high. I just lowered all 4 down to 27 psi but haven't taken it for a test ride yet. I do have to change the original shocks either way though.
Old Mar 28, 2024 | 07:25 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I installed Monroe SensaTrac shocks. They ride like a SUV. I went to the Monroe shock dimension chart to see what shocks would fit.
You wont be turning any 70mph sharp curves though.
Old Mar 28, 2024 | 08:59 PM
pete315's Avatar
pete315
Not sure what you mean by riding like a SUV. Is it bouncy?
Old Mar 28, 2024 | 10:15 PM
Bikespace's Avatar
Bikespace
What rear spring do you have? The mushy Hyperco composite spring, or the steel leaf spring, that was only in Gymkhana cars in 1981?
I have Bilstein Sports in my 80 (with a stiff composite spring). It is firm, but not "hard", and is less bouncy than my 2022 Mustang.
What car are you comparing the ride to?
Old Mar 28, 2024 | 10:29 PM
pete315's Avatar
pete315
Not sure exact rear spring but it’s not the steel one. It’s the original spring that came with car. I owned an 89 Vette and I think it rode on the highway better. This 81 has no forgiveness with any bumps on roadways. I’m sure 43 year old shocks is the main reason for the hard ride.
Old Mar 28, 2024 | 10:41 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm pretty happy with my Bilstien shocks. I tried some inexpensive shocks a few years back.
Wasn't really worth the effort to install them.
I realise your inquiring about low cost options.
Just saying this is probably a bad place to cut corners.
Old Mar 28, 2024 | 11:20 PM
riverracer au's Avatar
riverracer au
Do it once, do it right....
10yrs ago I put a set of Monroe SensaTrac shocks in my '72..
Have just replaced them last month with Bilsteins as recommended by most on here.
The Monroe's were worn out, no compressive rebound left at all, push them in and they stayed collapsed..
Old Mar 29, 2024 | 03:47 PM
doorgunner's Avatar
doorgunner
How about.....rides like a sedan.
Old Mar 29, 2024 | 06:12 PM
Midnightsun1's Avatar
Midnightsun1
Just my 2 cents I’d go back in with 10/90 oil shocks and you will get the ride and ride height the gm engineers wanted you to have. Stay away from 50/50 gas shocks
Old Mar 29, 2024 | 07:20 PM
pete315's Avatar
pete315
Still looking at shocks but I did test drive car with the tire pressure deceased to 27 psi from 36. Made a big difference. Not as hard as before and car still handles great. I was pushing car on off ramps and noticed no decreased handling. As I was backing car into driveway, I heard a rather loud clicking come from right at the left tire, not in middle of car. As I creep forward or backwards, car keeps clicking. I’m guessing half shaft u joints are bad. Those bad u joints probably are the reason I got a slight vibration in the rear. I’m going to change the u joints in both half shafts.
Old Mar 30, 2024 | 04:28 PM
airframer84's Avatar
airframer84
I have the Bilstien non-sports on my 78, paired it with a 330? Composite spring, I’d have to climb underneath. Regardless, I DD mine and it rides great, better than I could ever expect it to ride.
To Shocks
