What is this wire
Old Mar 30, 2024 | 07:06 AM
609Frankm's Avatar
609Frankm
Default What is this wire
What is this does it go to the radio and could I disconnect it that looks like a resistor
Old Mar 30, 2024 | 12:53 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It always helps to diagnose something when you state the year of the Corvette in question. There were many changes from '68 to '82 - especially regarding electricals.
No clue, but where does the other end of the yellow wire go? Is the bare black wire connected to this little board?
Old Mar 30, 2024 | 03:19 PM
609Frankm's Avatar
609Frankm
Default 78 corvette
Sorry it's a 78 the wires are yellow and brown
Old Mar 30, 2024 | 05:20 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Yellow zip ties were not factory in 78.
are you referring to the slender black tube on the brown wire when you say it looks like a resistor?
That's an inline fuse holder.
Can you disconnect it?
Yes, I give you permission.
Does it go to the radio, highly likely that it could be wiring for a aftermarket radio.
follow the wires.
What stops working when you disconnect it?
Old Mar 30, 2024 | 10:57 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
What is this? - CorvetteForum - Chevrolet Corvette Forum Discussion
Linked this thread for the pic.
Installs in the wiper slot of the fuse panel in place if the glass fuse for delay wipers.
Otherwise tucked up out of the way.
No, it won't give you delay wipers if not originally equipped with them.
Old Mar 30, 2024 | 11:03 PM
KapsSA's Avatar
KapsSA
To What is this wire
