Temperature Gauge
Old Jun 19, 2024 | 08:12 PM
virtue4u's Avatar
virtue4u
Default Temperature Gauge
The temperature on the gauge is correct for about 10 minutes until the engine gets up to temperature. Then, the needle drops from the correct 180 temperature to 150 degrees. It stays on 150 degrees for about 5 minutes and then will occasionally bounce back up to the correct 180 degree temperature for about a minute before falling back down to 150 degrees. Does this sound like a problem with the sensor, wiring or gauge?
Old Jun 19, 2024 | 08:57 PM
Peterbuilt's Avatar
Peterbuilt
Default Could be this easy
How old is your thermostat?
Old Jun 19, 2024 | 10:13 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Agreed, sounds more like a bad thermostat than a bad gauge. Perhaps the gauge is just fine and you actually have a problem. That's why we have gauges.
Old Jun 20, 2024 | 07:24 AM
Bikespace's Avatar
Bikespace
What year and engine?
First, I'd confirm with an IR temp gun (Harbor Freight, or Amazon, cheap and useful).
If you have a 77-82, I'd wiggle the connector in the back of the center gauge cluster, if you can reach it (easy with no glove box insert!).
Old Jun 20, 2024 | 09:27 AM
virtue4u's Avatar
virtue4u
It is not a gradual change. The way the temperature gauge needle occasionally snaps back from 150 to 180 degrees makes it appear to me to be an electrical problem, not a mechanical problem with the thermostat.
Old Jun 20, 2024 | 09:32 AM
virtue4u's Avatar
virtue4u
It is a 77. I was afraid someone would say to mess with the connectors behind the instrument panel. I thought that it might be a bad connection, but I was so hoping someone would say that I definitely have a bad sensor.
Old Jun 20, 2024 | 10:06 AM
Bikespace's Avatar
Bikespace
The sensor isn't going to change resistance that quickly. A loose connection might.
77 still has the map pockets, right? Hopefully it's not back there.
What else happens when you get up to temperature? Do you have a bad engine ground? Is your alternator going on and off charge? Is your voltmeter showing anything wonky? Electric choke or other mods? Please post some photos!
Old Jun 21, 2024 | 02:01 AM
virtue4u's Avatar
virtue4u
Voltmeter is fine. The problem seems electrical to me, and I feel that the problem is in the engine bay because the problem seems related to heat. The temperature gauge will correctly read 180 degrees for 5-10 minutes when driving, but then it will suddenly drop to 150 degrees, stay there at 150 degrees for 5 minutes and then briefly snap to the correct temperature of 180 degrees for only a few seconds at a time. Most of the time the gauge is reading low at 150 degrees. I can catch the correct 180 degree reading only every once in a while. Hmmm, bad engine ground could be the problem. Where is that ground located?
Old Jun 21, 2024 | 03:18 AM
Bikespace's Avatar
Bikespace
Is your AC compressor cycling when this happens? Electric cooling fans? I'm trying to think of other periodic loads that only occur when hot.
Old Jun 21, 2024 | 08:56 AM
virtue4u's Avatar
virtue4u
I don’t have an electric fan, and the erratic behavior of the temperature gauge needle happens with or without the A/C on. I am out of town and away from the vehicle right now, but as someone suggested, I am going to check my engine ground when I return. It acts like a ground problem that somehow gets worse with engine heat. The vehicle is 47 years old and quite frankly I never gave a thought about the ground or ever cleaning the ground. I will post the results after cleaning or replacing the ground wire. Gosh, without ever lifting a finger (except on the keyboard) am getting some great ideas on a possible diagnosis. Thank you all, and stay tuned.
Old Sep 5, 2024 | 12:27 PM
sc4ram's Avatar
sc4ram
How did you make out with this ? I have a '82 (built in '81) 454 that does almost the same thing. My gauge doesn't have temp increment hash marks but reads Cold-to-Hot (C -to- H). When the engine starts cold, the gauge points all the way to Cold, when it warms up (I'd guess correlated to the thermostat opening) the gauge simply bounces around. In my case, it can't be a thermostat problem, because I've driven it 85+ miles with no over heating. (Slowly over time, I've noticed other gauges acting erratically when operating at full temp for a extended period of time)
Old Sep 6, 2024 | 02:19 AM
virtue4u's Avatar
virtue4u
Cleaning the metal at the large passenger side ground cable fixed my problem. If your gauges are acting erratically when the engine warms up, then check the big ground cable connection on the passenger side.
Old Sep 6, 2024 | 04:41 AM
4-vettes's Avatar
4-vettes
On my car, several years ago, I found that ground cable going green under the insulation. I replaced that ground cable and my charging system became more robust, and all kinds of little things suddenly became better.
Fairly inexpensive part that can help a lot!
Old Sep 6, 2024 | 09:33 AM
sc4ram's Avatar
sc4ram
Thank you, are you talking about a ground wire to the dash-board on the passenger side? or the big battery ground?
Old Sep 6, 2024 | 10:45 AM
virtue4u's Avatar
virtue4u
I am taking about The big battery ground on the passenger side. I cleaned up the metal at the connections and the temperature gauge stopped being erratic when the engine got warm. I found that the area is kind of “tight” getting to those connections. I had to try several tools to find one I liked for turning the connections.
Old Sep 6, 2024 | 10:56 AM
sc4ram's Avatar
sc4ram
Interesting, presume you are talking about where the ground from engine battery eventually contacts the frame?
Old Sep 6, 2024 | 11:54 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Sounds like a bad sensor. IF it was a short it would peg the pother way I believe.. It culd be a broke plastic board and its going open
Watch this and figure it out
Old Sep 6, 2024 | 07:35 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
3rd party jumping in here to hopefully clarify things...
The ground that goes from the battery to the frame is on the drivers side.
Dash panel ground is on the driver's door hinge pillar.
The engine ground I think the OP is talking about is on the passenger side going from the starter brace to the frame's engine mount arm.
Never hurts to check & clean ALL grounds
Old Sep 6, 2024 | 10:54 PM
virtue4u's Avatar
virtue4u
Yes, the engine ground on the passenger side. Sorry.
To Temperature Gauge
