Tips for buying
I’m looking to buy a new ‘69-‘79 corvette. I’m kind of new to this and was wondering if any of you had tips for buying or something to look out for (like if there’s a common issue with these cars or something you’ve learned). I’m sure this thread already exists, but I couldn’t find it. I appreciate all contributions. Thanks!
although thread wanders, worth a read.
https://www.corvetteforum.com/forums...orvette-6.html
https://www.youtube.com/watch?v=SgRgAppx0d4
A couple of videos that might help
What are your skills/experience in working on cars?
What are your expectations regarding how much time are you willing to invest in maintaining/repairing the car?
What is your emotional tolerance regarding dealing with unknown situations?
These cars are, on average, 50 years old. Good parts are not easy to find. Qualified mechanics willing to work on them at reasonable rates are even harder to find. If you have little to no mechanical experience and/or no time to spend working on the car, then they are not a good choice for you. On the other hand, if you do have some skills, are willing/able to devote time to research/learn/fix/etc. without upsetting yourself and your family, then owning a C3 is a wonderful experience.
So, if you are in the latter group, then educate yourself first on the birdcage.
Friday nights, she goes up on the jackstand for new parts. Sunday afternoon she comes down and hits the road. Something breaks and Im posting here Sunday night. Monday morning, Im ordering parts..... repeat, repeat, repeat
Since you are new to the C3's I would have a "Vette" mechanic/body guy look at any C3 you are considering from top to bottom.
Maybe contact a local car club to find that person?
My car was always extremely reliable. Giving me very few troubles the first 30 or so years. That's actually pretty darn good for a 70's car.
but the last 15 years I have repaired or rebuilt just about every part of the car. I do not find this upsetting. It's old! It was never designed to last this long.
That said. If I had to pay someone every time something needed repair. I just couldn't have it.
For all of its flaws I really enjoy my C3 for what it is.
I don’t believe the Corvette is a mechanical failure. It’s a specific, unique bird, but as it’s been around since the 50s, most everything that’s gonna break on them have. And essentially nothing is unfixable unless your frame rusts in half -but then again, you can fix that too.
Im also going to disagree that if you can’t fix these cars yourself, you can’t afford them. If you make a stupid purchase or foolishly buy a project car, well, maybe. Or if your budget isn’t ready for an old car, maybe not. But if you stick to the golden rule of “buy as much car as you can afford,” then find yourself a trustworthy shop and understand you are gonna have a long term relationship with them. There may be things you can learn to fix if you want to, but I’ve had 19 corvettes since the 70s and I’d never describe myself as a mechanic. I know many other owners who were the same.
Dont be chased away by thinking you need to become a mechanic if that’s not something you want.
***Repairs completed***
Fuel Pump - leaking gas
Rubber fuel lines - swollen
Fuel filter
Oil/filter change
Borgeson power steering
Brake hoses
Brake line light/distribution block - leak
Power busbar in engine compartment - electric fan
Painless electric relay harness - resolve overheating
Thermostat and flush cooling system
Alternator bracket - snapped in half
Radio/speakers
Master cylinder gasket - freshen up
Oil pressure sending unit - leaking
Coolant temperature sensor connector - broken
Intake manifold bolts leak - thread seal
***repairs that need to be done***
Transmission rubber hoses
Gas tank sock
Snubber bushing
Carb Rebuild - gasket seeping
AC
Seatbelts - rusted
Front end suspension
Speedo cable
Starter heat shield
Starter
Coolant cap
Battery
Luggage rack rust
Adjust T-top
Adjust window
Clean and lube door locks
Valve cover and gasket
Transmission fluid, gasket, filter
Rebuild window motor
This was a nice running and driving car. Dealer wanted $18,000, dropped to $13,000 after 5 months. I offered $11,500 cash. Did I expect the repair list? No. But at the end of the day, I got the exterior/interior options that I wanted. I don't regret it.
60
Joey's list:
Fuel filter
Oil/filter change
Brake hoses
Radio/speakers
Gas tank sock
Snubber bushing
AC
Seatbelts - rusted
Speedo cable
Starter heat shield
Starter
Coolant cap
Battery
Luggage rack rust
Adjust T-top
Adjust window
60
OTOH.... there's no better way to learn than by doing. And if you like learning about cars/maintenance/resoration...then there's nothing wrong with a solid (key word there) project as long as you know what you're getting into.
Go drive a few and see what you think. The seating arrangement is very different. If it doesn't suit you, I would suggest considering a mid to late 70's Trans Am, or even one of the newer (revival) pony-cars.
The 82 Corvettes, although not in your year range, are going to most likely ride smoother, and be the best drivers due to being lighter, fiberglass rear leaf spring, EFI (as long as it's running right), and the OD transmission. Just the OD transmission almost makes an 82 worth consideration. If you like the looks of the shovel-nose-vettes.
The Camaro is local car show hot rod.
The Mustang is our long distance rod rod. Cooled seats and ac is sweet when it's 80 plus temp wise.
Go out and drive a C3 and then drive a late model hot rod.
