Tires and wheels
Old Jul 18, 2024 | 05:47 PM
Liquidasset89's Avatar
Liquidasset89
3rd Gear
Default Tires and wheels
Replacing tires on my 1974 C3. Installing BF Goodrich TA's P255 60R 15s (front and back) and the wheels are in poor shape. Looking to buy new wheels, are these standard GM Rally wheels, 15 x 8 w/ 5 @ 4.75 mounting?
Installing same tires that is on it... just want to confirm correct wheel to purchase and install. Any suggestions?... Suggested vendors?
Old Jul 18, 2024 | 05:55 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Get them sand blasted and repaint. Or scuff with snd paper and paint Unless they are bent
Old Jul 18, 2024 | 06:11 PM
Liquidasset89
3rd Gear
The two I am looking at both have curb dings and some corrosion on inside. Prefer to install new. I see confusing information where some state 7's on front and 8's on rear. Some comments claim 8's all around.
What was original?
Old Jul 18, 2024 | 06:13 PM
gbvette62's Avatar
gbvette62
The original "AZ" code rally wheels on the Corvette were 15x8 with a 4" back spacing, not 4.75". None of the repro wheels available are exactly the same as the original wheels, though they do look the same as original once the trim rings and center caps are installed.
Personally, unless your wheels are bent or severely pitted, before I bought some Chinese replacement wheels I'd try sandblasting and repainting your original one, like Nowhere Man suggested.
68 Corvettes were 15x7 front and back, 69-82 were 15x8 at all four corners.
Old Jul 18, 2024 | 06:14 PM
SEVNT6's Avatar
SEVNT6
7" wide was '68 only. 8" after that on all four...
Old Jul 20, 2024 | 12:20 AM
Mark G's Avatar
Mark G
LOL...I'd probably go new.
I bought 6 decent looking aluminum C3 wheels from various sellers from the internet and one from a swap meet. They're in pretty good condition (by looks) and need to be polished...but they're not super oxidized. I put the bare rims on the spindle (tightened down to no play) ... my spindles are 'trued'. Put the dial indicator on them. Guess what? Every wheel has warpage! LOL. More than I want to deal with. It's not the spindle or the hub..I checked the outside and inside ...it's the wheel/s. I double-checked on the other spindle. A lot of Corvettes were rough-housed over the years. Technically they'd work "ok", they're not THAT bad. But more than I want. If I'm going to put work into polishing wheels, I dont want them bobbing up/down at 70mph on the highway. Therefore, I would recommend considering *new* unless you know some used ones are real nice.
Old Jul 20, 2024 | 01:26 PM
Liquidasset89
3rd Gear
Thanks for the reply's and guidance on this topic. I work in my garage not a shop. Pulling all four tires, removing from rims, sandblasting painting and reversing the procedure is not my idea of spending 2-3 weekends. I am going with new wheels and have the new tires mounted, and I can change tires in a couple of hours. Can anyone suggest a line of "Built in America" GM style rims and where I can source them?.... or is everything new imported? Again, thank you to all that take a few minutes to respond....
Old Jul 20, 2024 | 04:48 PM
Nowhere Man
so why cant you remove the wheels and tires and use some elbow grease with sand paper, or scotch brite pads or a wire wheel on a drill and remove all the rust, paint then prigemer and paint, then have the tires removed and get new tires put on?
Old Jul 20, 2024 | 07:59 PM
SEVNT6's Avatar
SEVNT6
Coker Rally's are U.S. made.
www.coker.com
To Tires and wheels
