Muncie Tranny Problems
Old Jul 21, 2024 | 10:03 PM
Marco Romero's Avatar
Marco Romero
Default Muncie Tranny Problems
Hey there!
I just installed a Muncie 4 speed on my 81’ as the t-10 blew up on me a couple months ago. However with everything installed I’m running into a problem with the shifting. I can’t seem to get reverse, 1st or 3rd gear to engage. And I’ve tried looking at the linkage but there’s no binding between my shifter linkage and I’m not sure what else can be the problem. I know it’s not the clutch because 4th was able to slowly engage the car forward. I could really use some help. Thank you!
Old Jul 22, 2024 | 08:23 AM
GTR1999's Avatar
GTR1999
Reverse is the only gear to actually move to engage. 1 & 3 are on different hubs. I would be looking at the shifter linkage adjustment again as long as you checked the Muncie before you installed it in the car. If you have a lift, you can remove the linkage at the trans and see if the gears engage by a wrench.
Old Jul 22, 2024 | 11:24 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Well,
One option would be to disconnect the shifter arms, and shift the trans with a wrench. Adjustable or channel locks. BTDT.
Make sure all the gears work as they should. You should feel a strong click.
Then move the shifter and make sure the rods move as they should.
Then make sure the angles of the shifted trans selectors and the shifter rods match.
I forget whether the shifter linkages goes down to the trans, or up. They can easily get put on upside down.
The 1x2" selector lever, all by itself, needs to lock on to the trans selector **** very solidly.
Something should be obvious by that point.
Maybe someone knows if there is any difference in the shifter selectors on the trans between Muncies and S-T10s.
Old Jul 22, 2024 | 05:38 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Leigh,two people are the key.mine I know isn’t right but when you are by yourself
it’s extremely difficult.thats mys problem anyway!
Old Jul 23, 2024 | 11:51 PM
crf311's Avatar
crf311
Shifter adjustment and clutch adjustment. Just went through some shifting issues after I rebuild my Muncie along with a new shifter..just my .02
Old Jul 24, 2024 | 11:06 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Have you gone thru the factory shifter adjustment procedure?
It requires a special tool or pin or you make one.
Old Jul 24, 2024 | 11:38 AM
dons70vert's Avatar
dons70vert
check the spring that goes with the rod that gets inserted in the shifter. unscrew shifter ball and check if the spring is in right.
Old Jul 24, 2024 | 01:43 PM
pigfarmer's Avatar
pigfarmer
On my '69 M20 with the linkages disconnected I could easily move the levers ( that are pointed up ) with my hand and they gave a very positive 'click' in each direction. 3/4 are the ones closest to the front, then 1/2 and reverse gear is in the back.
The transmission shift levers have upper and lower holes - the bottom ones being for the 'short shift option'. I much prefer that and so do many who make the change. It's like a rifle bolt now, not a trip around the barn.
Cotter pins can work but I used the proper G-clips it's supposed to come with and they hold the linkages in place correctly, the cotter pins don't seem to. The adjustments aren't really very much and I assume cotter pins must make enough of a change to matter. Small, weird but that's what I found and my life improved when I used the g-clips. I assume GM had a reason for using them.
On older shifter you could use a feeling gauge to lock it into it's neutral position. I think the newer ones may be a round hole, so a drill bit or screwstick might work.I wound up pulling my shifter and squaring it in a vice. Getting it in and out while laying on my back was not impossible but cost me a lot of ibuprofen.
Hope this helps.
Old Jul 29, 2024 | 09:24 AM
stingr69's Avatar
stingr69
The shift levers that bolt to the shift shafts exiting the transmission must match the vintage of your new Muncie. Muncies have 2 different style of shafts depending on year of original application and the tranny levers are not compatible with each other. Might not be compatible with the T-10 tranny either but I am not sure there. All the shifter parts & pieces need to be right... and match the transmission... and match the car model.
To Muncie Tranny Problems
