hood problem
Old Aug 14, 2024 | 12:00 AM
75guy76vette's Avatar
75guy76vette
Default hood problem
How do i open the hood on a 76? the passenger latch side is open but not the driver side. the cable is moving from the latch and i can feel it moving when i put my hand on the hood but the driver side is tight and wont open.
Old Aug 14, 2024 | 12:39 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
the first thing to try would be to gently push the stuck side down while having someone operate the hood release. taking the pressure off the latch might assist it in operating. if it does work, be certain to check the cable attachment to the latch release and lubricate both sides with lithium grease or something similar for the future.
Old Aug 14, 2024 | 01:20 PM
Mark G's Avatar
Mark G
It's not an uncommon C3 problem. Could be the cable.
Some guys here who've been through that will hopefully chime in. I haven't had mine break or not open, so I'm not the resident expert.
Old Aug 14, 2024 | 02:42 PM
Mr E's C3's Avatar
Mr E's C3
Here are a couple of things to try:
I would recommend someone to help if possible.
First make sure the hood on both sides is latched and gently(relative term) apply a little pressure to side the is not releasing while someone else is pulling on the release cable, the pressure applied can be downward ,upward, side to side or combination. This of course assumes there is not a problem with the release cable.
If not luck with above method ,on my 76 there is a plastic plug in the wiper well that is directly behind the latch, with a diagram and lock tools or screw driver you may be able unlatch hood. Since this method requires being up close and personal with the windshield a hand small mirror and light is recommended.
The next method if you have the lower splash behind the fender liner you can remove it once the rocker molding is removed and reach your arm if long enough and trip the latch. Gloves recommend since the cable ends can be quite sharp.
The last method is a huge PIA . You loosen the hood bolts accessible with the headlamps up and the headlamp door removed, the bolts can be turned maybe 1/8 turn at a time. When the hood is loosen enough it will allow laches to release assuming there is no problem with cable.
Yes I have had to use all methods at one time or another. If you up loosen hood bolts make that you realign hood before closing it again.
Good luck
To hood problem
