TH350 assembly oil/fluid
Old Aug 19, 2024 | 08:01 AM
Novusuhu's Avatar
Novusuhu
Default TH350 assembly oil/fluid
Hi everyone
This week I will start the rebuild (partly) of my TH350, because the front pump is leaning badly.
I've got the whole gasket set, o-rings, ... etc.
I've watched some youtube video's, where they change the big O-ring seal. It's said that you have to lube it up first with some assembly lube.
Can I just use some transmission oil? Or what is best used for this?
Old Aug 19, 2024 | 08:54 AM
interpon's Avatar
interpon
i didn't know transmission assembly lube existed until i rebuilt my Super T-10... my guess is it helps hold the o- ring for assembly as it is tacky. if positioned correctly i would assume OK unless the transmission fluid can damage o ring? i wouldn't sweat it if positioned correctly.
Old Aug 19, 2024 | 10:08 AM
Eric P's Avatar
Eric P
ATF will be fine for that O-ring or some Vasoline, I coat the case with a thin film of assembly lube and leave the O-ring dry to help the O-ring slide into place when you bolt the pump up to the case , assembly lube is nice but the main thing is don't install dry which the ATF will work for a one time deal , install new pump bushing if it looks wore but you have to separate the pump halves and need an alignment band for assembly or a bunch of hose clamps connected to each other to wrap around the pump halves ... be careful with the two sealing rings on the end of the pump too , they are very important and need some assembly lube or Vasoline on them before the install
Old Aug 20, 2024 | 12:25 PM
7T1vette's Avatar
7T1vette
If you have leaks at the front of the trans, the bushing in your pump is worn out. IT MUST BE REPLACED. You need the right tools and a good power press to install it properly (without damaging it). Any oil will work for reassembly: ATF, petrolatum, motor oil, etc.
If you are planning to use synthetic tranny lube in the unit, use that for assembly also.
Old Aug 20, 2024 | 01:38 PM
Novusuhu's Avatar
Novusuhu
​​​​​​I think the bushing is in the kit I bought.
​​​​​​ Will look.in to it.
I have a hydraulic press, so that will be OK.
Old Oct 10, 2024 | 07:37 PM
7T1vette's Avatar
7T1vette
You need to align the bushing properly when pressing it in. An alignment tool with the proper pilot diameter is a real help to prevent 'buckling' of the bushing. You can do without it...if you are really careful.
To TH350 assembly oil/fluid
