10W60 zz4 engine
Old Sep 30, 2024 | 12:17 AM
teknikeren09's Avatar
teknikeren09
7th Gear
Default 10W60 zz4 engine
Hi,
I have a Corvette c3 1980 with a ZZ4 Crate engine.
i have looked around the internet, and saw that the engine runs good on 5w30 and 10w30.
but inside the car, there is a slip of paper from po and his workshop.
on this paper, the workshop have written 10W60 racing.
so i was just wondering, should i stay with 10W60 or go for 10W30?
I live in Denmark, so it can get cold, but its shut off the entire winter.
Old Sep 30, 2024 | 07:06 AM
gbvette62's Avatar
gbvette62
Below is a link to the Chevrolet specification sheet for the ZZ4. If you look at page 6 you will see that Chevrolet recommends 10W30 synthetic oil, after engine break in.
https://www.chevrolet.com/content/da...e-24502609.pdf
Old Sep 30, 2024 | 01:30 PM
Sayfoo's Avatar
Sayfoo
The vast majority of engine wear occurs at start up when the oil is cold and thick.
What is cold?
Denmark cold may be construed differently than southern California cold.
I think the benchmark is about 40-50 deg. fahrenheit. 10w/30 above and thinner below, maybe 5w/20 below.
60 weight is way too thick for normal driving.
Old Sep 30, 2024 | 04:40 PM
71 Vert LS1's Avatar
71 Vert LS1
Never heard of 10W60. 10W50 yes.
Old Sep 30, 2024 | 07:19 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
10w50 or 20w50 will have a significant amount of ZDDP for a flat tappet engine. If you run just any oil in a flat tappet engine you will have a greater chance of flattening the cam lobes and dishing the lifters. If you didnt build it, go with what the last owner said to use, there is probably a reason
Old Sep 30, 2024 | 07:49 PM
Rescue Rogers
Also the thicker oil will give you a thicker cushion in your main and connecting rod bushings, I run it in my 427 and its 70 psi all day long
Old Oct 1, 2024 | 05:35 AM
teknikeren09
7th Gear
I did not build the engine, but i do believe, that a ZZ4 engine is a hydralic roller cam, so no Zinc is needed.
The last owner did not know much about the engine, he had a local mechanic that he used.
I work as a salesman at Toyota, and my mech, says a should just put the recommended on (10w30)
because 10w60 would be too thick for my type of driving (not racing or anything wild)
Old Oct 1, 2024 | 05:38 AM
teknikeren09
7th Gear
50 on a very cold day in the summer, and about 75 on a hot day.
we do have a couple of days where we get a little over 86. but thats not a lot during a full year
from 15 of October until the 15 of march, the car is in a garage, where humidity is controlled but its not heated
Old Oct 1, 2024 | 11:58 AM
MelWff's Avatar
MelWff
10W30 is the correct viscosity as Chevrolet recommended
Old Oct 8, 2024 | 04:50 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
What's 10W60? HAHA!
Old Oct 8, 2024 | 04:56 PM
MelWff's Avatar
MelWff
Originally Posted by TKX 5-SPEED C3
What's 10W60? HAHA!
What's funny?
10W60 10W60
Old Oct 8, 2024 | 06:15 PM
Rescue Rogers
Probably the fact he has 21 posts and he's from CA....must be a Facebook blow in
To 10W60 zz4 engine
