Odd Parts ID Request
Old Oct 9, 2024 | 11:12 AM
68/BB's Avatar
68/BB
Default Odd Parts ID Request
Some random left over parts I am not sure what to call them or exactly where they go. Actually, I believe the small ceramic block goes with the distributor and was mounted on the firewall. I do not know if it is an aftermarket kind of part or what it is called. These should be from a '68 but not certain. All help is appreciated.
Old Oct 9, 2024 | 11:38 AM
69L88's Avatar
69L88
The ring sits on the transmission tunnel for the shifter lever. The item on the right is a transistorized ignition module.
Old Oct 9, 2024 | 11:51 AM
pigfarmer's Avatar
pigfarmer
top thing looks like a ballast resistor
Old Oct 9, 2024 | 11:52 AM
Goodpmsvette's Avatar
Goodpmsvette
Default Odd Parts
Here is an ebay link showing what looks like one of your items. Looks like a Shifter Boot Retainer.
1968-1976 Corvette GM 4 Speed Underbody Shifter Boot Retainer | eBay
Old Oct 9, 2024 | 11:54 AM
Tampa Jerry's Avatar
Tampa Jerry
The ceramic part, as mentioned above, is a ballast resister. They were used on 67 and earlier Corvettes. Starting in 68, GM used a resister wire instead of the ceramic block. Jerry
Old Oct 9, 2024 | 02:32 PM
68/BB's Avatar
68/BB
I wonder if this is a date code or a part number on the ignition module?
Old Oct 9, 2024 | 02:45 PM
Bills17n72's Avatar
Bills17n72
Old Oct 9, 2024 | 02:51 PM
68/BB's Avatar
68/BB
Possibly Jan 10, 1968? That would coincide with the build date of my car.
Old Oct 9, 2024 | 03:19 PM
69L88's Avatar
69L88
Yup, sits on the leading edge of the left front inner fender well.
Old Oct 9, 2024 | 04:19 PM
68/BB's Avatar
68/BB
Interesting, I would have assumed firewall but it is pretty crowded back there.
Old Oct 9, 2024 | 04:37 PM
bazza77's Avatar
bazza77
There will be three holes drilled for the mounting of that ignition module, or there's 3 dimples in the glass to indicate where to drill
Old Oct 9, 2024 | 05:00 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
having TI validates having a solid lifter BB car as that was a required option. do you have the TI dist?
Old Oct 9, 2024 | 07:21 PM
68/BB's Avatar
68/BB
No, just this part. I used an HEI when I put the BB in the car a few years ago. Just cleaning up and found this old part and did not know what it was. I bought the car in boxes and although it is together now there were some maverick parts to wrangle up. This was one of them.
Old Oct 9, 2024 | 07:23 PM
68/BB's Avatar
68/BB
Does anyone know if that TI module can be bench tested?
To Odd Parts ID Request
