Air Pressure
Old Oct 12, 2024 | 05:02 PM
anewguy's Avatar
anewguy
Default Air Pressure
How much air, in tires of a 80 Corvette, for best ride ?
Old Oct 12, 2024 | 06:12 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
For best ride quality you would run them a bit on the low side.
That said, it does matter to some degree which tires you are running.
Myself, running 255/60-15's for over 35 years and a couple different brands have always run 32 PSI all the way around and have gotten excellent tread wear and decent handling.
Perhaps around 30 PSI for best ride quality would be a good starting point.
Old Oct 12, 2024 | 06:36 PM
MelWff's Avatar
MelWff
30 PSI, no lower
Old Oct 12, 2024 | 07:59 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Originally Posted by MelWff
30 PSI, no lower
You don't want to slide around unnecessarily.
Old Oct 12, 2024 | 08:42 PM
bagger327's Avatar
bagger327
2025 C3 ('68-'73) of the Year Finalist - Unmodified
I have a '79. Running Cooper Cobras, 255/60-15. Factory door sticker states: Cold Air Pressure/ 30lbs front - 35lbs rear.
For best fuel economy: 20lbs front - 26lbs rear. I run 28lbs all around and like the ride I'm getting.
I have also rebuilt the entire suspension which made a heck of difference in ride and handling. Good luck.
Old Oct 12, 2024 | 09:21 PM
LT1M21Vette's Avatar
LT1M21Vette
Good tire choice.
I like to run closer to 40 psi. Better handling.
Old Oct 13, 2024 | 05:28 PM
anewguy's Avatar
anewguy
Originally Posted by LT1M21Vette
Good tire choice.
https://www.youtube.com/watch?v=EftZ1BCr5uA
Must ride like a rock.
Old Oct 13, 2024 | 05:43 PM
LT1M21Vette
Drives a Corvette, wants a soft and plush ride?
Old Oct 14, 2024 | 12:10 PM
anewguy's Avatar
anewguy
Default 40 seems like a lot.
Hmmm !
Old Oct 19, 2024 | 12:40 AM
7T1vette's Avatar
7T1vette
Depends on the tires used. But, 30 psi is a good place to start. Go no lower, unless you KNOW that the tires you have are capable of such lower pressure.
P.S. When radial tires first made it to Corvettes (mid-70's) the GM engineers mistakenly thought that wide tires should have less pressure and actually spec'd them for mid-20 psi levels. BIG MISTAKE!! Lots of tire failures from over-flexing the sidewalls.
The Owner's Manuals for those cars and some tire pressure sticker repro's still call out those low pressures. DO NOT DO SO.
Old Oct 19, 2024 | 01:15 AM
4-vettes's Avatar
4-vettes
those tire pressure labels from 45/50 years ago were terrible when new and considering tires have evolved a great deal in over 40 years.......
To Air Pressure
