Soft Brake Pedal
Old Oct 16, 2024 | 04:15 PM
jazzman123's Avatar
jazzman123
2nd Gear
Default Soft Brake Pedal
I have a salvage title 77 vette, I am trying to restore. I have replace the brake booster, all 4 caliper and brake shoes. I bled the system numerous times, still the brake pedal is low (the car stops, but I am leery). Manual bleeding, pressure bleeding, nothing seems to bring the pedal up. What am I doing wrong here???
Old Oct 16, 2024 | 04:25 PM
Mark G's Avatar
Mark G
Did you ever get, or had a hard pedal after your previous bleedings? (I had to think of a good way of wording that!..ha ha). Or does the pedal go from a firm pedal to soft after driving it? Is it the same M/C that was on there when it was still working before all the work you did?
Are the caliper bleeder screws as you have the calipers mounted ....on the top?
Old Oct 16, 2024 | 05:00 PM
carriljc's Avatar
carriljc
Have you replaced the 4 corner brake hoses? You might try that if you have not and then do another pressure bleed.
Old Oct 16, 2024 | 05:20 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I have found with many years of experience, that air likes to go up, not down.
Think Phoenix brake bleeder. Pushes fluid up from the bottom. Pushes air out the top. Also, get the rear of the car up. So as to get master cylinder level or front slightly down to get all trapped air out.
Best of luck.
Old Oct 16, 2024 | 05:26 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Also, rear brakes have 2 bleeders on each caliper.
Old Oct 16, 2024 | 07:00 PM
HeadsU.P.'s Avatar
HeadsU.P.
Clue #1.
New booster. Why?
Is the new one a GM Delco or an aftermarket?
I assume the new booster was mated to the old master cyl?
What is the booster rod gap measurement?
It should be 0.060. Or around 1/16 of an inch.
Any less than that and the pads will drag the rotors constantly.
Any more than that creates way too much pedal travel, to the point where the master is not fully engaged until its too late.
Pedal is near the floor you ran out of room.
Old Oct 17, 2024 | 08:26 AM
RobertJ-C3's Avatar
RobertJ-C3
I'd do a gravity bleed for several hours while keeping an eye on the fluid level in the MC. It's been my experience that a "soft" system will benefit greatly from it.
Old Oct 17, 2024 | 10:34 AM
Xchief91's Avatar
Xchief91
Sorry to jump on this thread with another question but!!
The booster changed in '77 from the black painted style to zinc plated. When you look at the information on adjusting the rod and the tool(s) available to properly set the gap, it specifically indicates ’68 -‘76 model years.
So, was there more than an exterior coating change for the ’77 – ’82 years and the rod is not adjustable?
Thanks,
Steve
Old Oct 17, 2024 | 05:28 PM
4-vettes's Avatar
4-vettes
That's right Steve, you are high jacking this thread. And yes there is more of a difference than just color between 76, down and 77,up.
And if you swap both the master and booster at the same time as a matched set. You have no issues.
Old Oct 17, 2024 | 06:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Originally Posted by HeadsU.P.
Clue #1.
New booster. Why?
Thanks,
Steve
my first thought was rod length.
the masters/cyl have different style hole depth in piston thus rod length issues
Old Oct 17, 2024 | 07:42 PM
HeadsU.P.'s Avatar
HeadsU.P.
Some years the booster rod was threaded (in or out)
Other years, no adjustment.
The back of the master changed design along the way also.
Old Oct 18, 2024 | 12:23 PM
jazzman123's Avatar
jazzman123
2nd Gear
New user to the forum, navigation is not easy. That being I removed the master cylinder, (per suggestions) and discovered that there is zero clearance between the booster and master cylinder. The push rod came withe the master cylinder and is not adjustable. Can the push rod be bought separately? If it can, where should I look? This may correct my problem...thanks everyone
Old Oct 18, 2024 | 08:33 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have never seen a booster rod included with a new master cyl. Do you mean the rod came with the booster?
I am confused how you determined there was zero gap. There are only two ways to check that gap.
A special tool can be ordered on-line or a gob of clay and checking the impression in the clay.
Remember, 0.060 is a very small gap.
I doubt a booster rod can be purchased 1/16 of inch shorter.
Some members on this forum have actually ground down the rod end.
I do not recommend this.
Something else is going on with your combo. I suspect a mismatch of master & booster from two different sources.
Keep looking.
To Soft Brake Pedal
