Hardware for Windshield Wiper Arm Control Valve
Old Oct 20, 2024 | 10:13 PM
yuvalt's Avatar
yuvalt
Default Hardware for Windshield Wiper Arm Control Valve
Hi,
I have a 1970 and I'm trying to install a windshield wiper arm control valve. I have the bracket but I don't have any of the hardware that connects the valve to the bracket and the bracket to the car. Does anyone have this information? See diagram below.
Thank you!!
Old Oct 20, 2024 | 10:42 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Do you have the nut plate with the studs still there?
Did you look at Zip where the illustration comes from? Corvette Central has the valve and bracket too. With those two items you just need the appropriate fasteners. The bolts and J-nuts are GM part numbers 9409107 & 3826920. Do a search on the vendor sites for those numbers and choose the combination that gives you what you need.
https://www.corvettecentral.com/69-7...cket-to-653056
https://www.corvettecentral.com/c3-6...-switch-593127
Old Oct 20, 2024 | 10:56 PM
yuvalt's Avatar
yuvalt
Thank you! I do have the studs (one is half broken but I think has enough thread left), and have one of the nuts that screws on to it (it's a nut with tooth washer) but I don't know its size (it's 1/4 inch I think). Do you know the part number of these nuts? Thanks again
Old Oct 20, 2024 | 11:41 PM
yuvalt's Avatar
yuvalt
Found it in the AIM! GM 271172
To Hardware for Windshield Wiper Arm Control Valve
