Engine knock
Old Oct 21, 2024 | 06:34 PM
cpd114's Avatar
cpd114
3rd Gear
Default Engine knock
Bought a 1978 Corvette 4 speed with 383 stroker engine. It seems to want to keep running when you turn the key off. I hate having to let out the clutch to kill the engine. Is there anything I can do differently? Non-ethanol gas? High octane gas? Any suggestion is welcomed.
Old Oct 21, 2024 | 06:41 PM
randallsteel's Avatar
randallsteel
Engine run on, or “dieseling” can be caused by overly retarded timing, or carbon build up on top of the pistons.
I would start with a simple timing verification.
how many degrees are you running at idle?
Old Oct 21, 2024 | 07:19 PM
HeadsU.P.'s Avatar
HeadsU.P.
Sometimes a carbs secondary throttle blades are open a smidge at idle.
Old Oct 21, 2024 | 07:24 PM
cpd114's Avatar
cpd114
3rd Gear
I am not sure of the degrees. How can I tell? I'm not a mechanic but could check if I knew the steps.
Thx
Old Oct 21, 2024 | 07:42 PM
randallsteel
Thx
1. Head to Harbor freight for instance, or most auto parts store, buy timing light. Under $30 at harbor.
2. connect positive and neg clips to back of alternator, thus provides power to timing light.
3. Place plug clamp over spark plug wire #1.
4. Locate distributor, locate vacuum advance can. Disconnect hose from carb to vac advance can. Plug end of hose with a screwdriver or pencil or something.
5. make sure all wires clear of rotating parts, start car.
6. direct timing gun to balancer and read number off timing tab.
I’m sure there’s a YouTube video that shows everything better than I typed.
This may cost $30 and not be the issue. But if it is, very easy to address.
As headsUP mentioned, it could be related to the carb
Old Oct 21, 2024 | 07:51 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
welcome.
new member, new owner.
hate to be blunt but what was your plan for maintaining a 50 year old car?
Old Oct 21, 2024 | 07:59 PM
cpd114's Avatar
cpd114
3rd Gear
Originally Posted by calwldlife
welcome.
No plan, just always wanted a Corvette.
Old Oct 21, 2024 | 08:02 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
guess there are couple options.
learn or pay.
your dieseling could also be a fast idle.
what is your rpm at idle?
Old Oct 21, 2024 | 08:30 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
welcome.
I guess his plan was asking the people on Corvetteforum.com for advice?
Old Oct 21, 2024 | 08:58 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Thx
and then what?
Old Oct 21, 2024 | 09:06 PM
Newbomb2469's Avatar
Newbomb2469
Easy guys….new member asking for help. This is why many join the forum so they can learn.
To the OP, welcome aboard and there are many who will help you with your questions.
Old Oct 21, 2024 | 09:50 PM
Newbomb2469
If not running premium fuel, with a 383 stroker, it most likely has a higher compression ratio and would require premium fuel vs a lower octane fuel. This is probably unrelated to your dieseling issue, but your engine will thank you.
Old Oct 21, 2024 | 09:52 PM
Kingtal0n's Avatar
Kingtal0n
Get a video of the run on so they can see whether its hot spots and **** or just a faulty ign circuit or something
Old Oct 21, 2024 | 10:54 PM
Bikespace's Avatar
Bikespace
Exactly!
There are lots of electrical gremlins that can cause this.
Also, get an IR temp gun. Is your coolant temp elevated?
Old Oct 23, 2024 | 10:43 AM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
As others have mentioned, this problem is almost always because of insufficient idle spark advance or a too high idle speed.
To Engine knock
