79' Custom Center Console
Old Nov 3, 2024 | 05:51 PM
79FlightLine's Avatar
79FlightLine
Cruising
Default 79' Custom Center Console
Shout out to The Punisher. He made a post in 2017 updating his 75’ C3 center console gauge and that is where I got the inspiration from. It is very similar but slightly different.
Below is a list of equipment & parts with links. Some of this equipment has way more quantity than you need for this project, but I plan on doing other projects on the car and will use most of this again.
WAGO 221 Lever-Nuts
Amazon Amazon
Double Din Dash Mount Cage
Amazon Amazon
Automotive Connectors
https://www.amazon.com/dp/B0C27B4PSF?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B0C27B4PSF?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
16 Gauge Wire
https://www.amazon.com/dp/B07SG23DT1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B07SG23DT1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Spray Adhesive
https://www.amazon.com/dp/B0752XM8VN?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B0752XM8VN?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Double Din Android Radio
Amazon Amazon
Faux Leather Fabric
https://www.amazon.com/dp/B08F7Q1JHV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B08F7Q1JHV?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Heat Gun
Amazon Amazon
Heat Shrink Tubing
https://www.amazon.com/dp/B07WWWPR2X?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B07WWWPR2X?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Center Console Faceplate (Custom Order) by: comfortroll https://www.ebay.com/itm/274957387058
Crimp Connector Kit
https://www.amazon.com/dp/B0C8JPCXGK?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B0C8JPCXGK?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Environmental Splice Kit
https://www.amazon.com/dp/B0B1PSLWWF?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 https://www.amazon.com/dp/B0B1PSLWWF?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Auto Meter Gauges (Z-Series) https://www.autometer.com
Gauge size 2-1/16” (52.4mm)
Water Temp PN: 2635
Oil Pressure PN: 2634
Voltmeter PN: 2645
Metal plate with gauges installed
I was going to buy a piece of sheet metal and fabricate the plate for the gauges and double din radio to go in, but I found a guy on eBay (comfortroll) that makes plates for C3 center consoles. He didn’t make the specific set that I wanted so I sent him a PM asking if he could fabricate one with 3 gauges below a double din. He wasn’t sure but he txt me back about a week later saying he was able to do it and it fit perfect. Really nice guy.
Once I had a plate, I bought some faux leather fabric to make it look a little nicer. I scuffed up the plate and used some spray adhesive to attach the faux leather. The double din android radio I bought didn’t come with a “cage”, so I had to purchase that separately. I had to trim the back of the cage to make it fit because of the A/C vents behind the center console.
Faux leather just laid over the faceplate
Trimmed the back of radio cage
I decided to just cut up the original center console plastic to fit the metal plate that holds the radio and gauges. This portion of the project took a while. I would lay the metal plate on the existing console and trace the outline to cut. Then I used an angle grinder and a Dremel to slowly make small cuts until it fit perfectly. Before putting the 2 pieces together I put the plastic console in the utility sink and washed it with dawn soap and a toothbrush to get the 45 years of grime off it. I used epoxy to adhere the metal plate to the plastic console. I’m not sure if this is the best route but it seems to work.
Side view with trimmed radio cage
When it came to wiring, I wanted to be able to easily pull the center console if needed so I decided to create a 4-pin plug for the gauges. So, if I need to pull the console there are only 2 connectors (gauge & Radio) and the whole thing comes out. I didn’t show wiring the radio because it was just like wiring any other radio, nothing crazy.
Back of Console with gauges wired to connector
I also made a terrible schematic for the gauges in paint lol. I tapped off the original wiring harness below is what I used.
Pink-Black wire ->Pin 4 “12V switched ignition source”
Black wire -> Pin 1 “Ground”
I ran a new wire for the water temp & oil pressure sender. I wanted to have the fewest number of wires for my plug, so I used a WAGO 221 Lever-Nut to tie all the backlighting together.
For the oil and temp gauges, Autometer sends a sending unit with the gauges. You must use the sender with the gauge.
Gauge wiring schematic
I also replaced the front speakers and ran new wires for them. I haven’t put a trim piece around the radio yet but I will eventually.
This is how it was when I got the car.
Finished without radio trim piece
My plan is to redo the drivers dash with new Autometer Tach and Speedo and move the GEN light, fuel gauge to the drivers dash. I will be removing the seat belt light and low fuel light. When I get around to that project I will make another post about that.
Hopefully I explained this well. If anybody wants more pictures or a better explanation just let me know.
Old Nov 3, 2024 | 07:00 PM
kanvasman's Avatar
kanvasman
Excellent way to get a double din in a C3. I tried doing 6 gauges into that center pod and I managed to do it, all wired to a plug like you did. But by the time I finished it I had changed my mind. Ended up with Dakota Digitals. Hadn't thought of a double din though. But you nailed it, Form, fit and function.
Old Nov 3, 2024 | 08:45 PM
SixAddict's Avatar
SixAddict
I agree I recently purchased a C3 and would love to put a double din unit in to it. Thanks for the write up.
Old Nov 4, 2024 | 05:01 PM
79FlightLine
Cruising
Thank you! I went through several ideas and configurations before deciding on this one. I also looked into Dakota Digital and that was out of my price range lol.
Old Nov 4, 2024 | 05:02 PM
79FlightLine
Cruising
Awesome! If you decide to do it let me know if you have any questions.
Old Nov 4, 2024 | 06:50 PM
raycam01_au's Avatar
raycam01_au
just in the process of a similar build, will end up with an Sony Apple play double din unit, will be going with a Haltech dash with all the options in that unit, so now just working out where and how the rest of the bits will fall into place
When the B&M shifter went in, it opened up the endless options
yours looks awesome mate,
Old Nov 4, 2024 | 07:44 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
What about the gas gauge, where do you put it?
Old Nov 5, 2024 | 12:21 PM
rabinaba's Avatar
rabinaba
This looks awesome! I'm also looking to add a double din to my '81, and it seems both fairly easy and totally difficult!
Side note: Does anyone know of a double din that will track this information in lieu of the physical gauges? I'm of half a mind to just remove the center console gauges entirely and just access the information by navigating the "infotainment system"...if that's even possible.
Old Nov 5, 2024 | 03:49 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Pioneer AVH-3500NEX was my solution. Great job OP! It looks awesome!
Old Nov 5, 2024 | 04:19 PM
Piersonpie's Avatar
Piersonpie
The Edelbrock Pro Flo 4 comes with an android tablet that displays the engine vitals and can also double as an infotainment system. It would be neat to see it fully integrated into the dashboard though.
I could imagine that other aftermarket EFI/ECUs could be programmed into an app for a double din radio, although that’s outside my area of expertise.
If I could get a screen in that area that could replicate the look of the stock gauges while having other functions as well I would be changing it out in a heartbeat.
Old Nov 5, 2024 | 05:49 PM
79FlightLine
Cruising
I plan on redoing the console with the speedo/tach and moving the fuel gauge between the speedo and tach.
Old Nov 5, 2024 | 05:53 PM
79FlightLine
Cruising
So that is my long term goal and the reason I chose this specific double din. Its basically a tablet where I can go into google play and download normal apps like I would my phone.
So when I get to installing the Pro Flo 4 I can just connect my double din to the pro flo 4 ecu, download the app from the google play store and I will be able to setup, tune and monitor if needed all within my double din. Then switch back to android auto when I'm finished.
Old Nov 25, 2024 | 11:59 AM
VicandVette's Avatar
VicandVette
1977 custom gauges
1977 custom gauges
I did similar but 3D printed a complete new cluster.
Old Sep 1, 2025 | 01:14 PM
Thomnewberg's Avatar
Thomnewberg
Cruising
Looks great and I am planing on doing something similar in my 78.
Why did you put the 3 gauges below the radio vs above? Just curious.
Old Sep 1, 2025 | 01:16 PM
VicandVette
If I remember correctly there was limited clearance on the top due to AC duct
Old Sep 1, 2025 | 01:26 PM
79FlightLine
Cruising
Basically it was too narrow for the 3 gauges behind the panel. Putting the gauges on the bottom allowed for more room for the wiring behind the gauges.
Old Sep 2, 2025 | 07:30 AM
TorchZ51's Avatar
TorchZ51
I found it to be the opposite. The radio will most likely require more depth than the gauges. So mounting the radio at bottom will give more clearance.
To 79' Custom Center Console
Old Sep 2, 2025 | 12:48 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Here is another option if you want a big screen for your c3 with Apple car play and navigation. It is in the way of the climate control but you can move the screen to adjust it.
https://www.crutchfield.com/S-Saf1Tj...en-CAR813.html
Old Sep 2, 2025 | 01:10 PM
interpon's Avatar
interpon
beautiful interior..well done
Old Jan 4, 2026 | 10:45 AM
Acordrey's Avatar
Acordrey
Nice job! I think I'm going to go in a similar direction.
