Rear Gears
Old Nov 14, 2024 | 12:58 PM
Michaelchop's Avatar
Michaelchop
Default Rear Gears
My 70 LT-1 currently has 4.11 gears. Originally the car had 3.70 gears in it. I don't really don't like how high the RPM is at 40-60 mph. I think 40 mph is 2200 rpm and 45 to 50 is 2500 rpm. I won't be drag racing anyone, in fact keeping up with Camaro's, and Mustang's of today is not realistic...Tesla's forget about it. Having the fastest car wasn't my intent. I always wanted a badass car from this ERA. I have that. My roundabout question is putting 3.70 or even 3.55 lower enough lower the RPM that much. I'm hoping 3.70 would lower it enough to be worth it.
Old Nov 14, 2024 | 01:24 PM
OldCarBum's Avatar
OldCarBum
I would first think about what your rpm goal is for what you’re planning to use the car for now.
If you plan on cruising on the highways at 65-70 you might want to go to a 3:36 gear which would still put you at 3000 rpm in 4th gear.
This is assuming you currently have a 4 spd manual in it.
You might be better off leaving the 4:11’s in the rear and do a 5 spd TKX with a 0.64 5th gear.
If you have an auto then there are several overdrive automatic transmissions you can go with.
A lot of this really depends on all if any engine modifications you’ve made for drag racing as the camshaft can play a big part in performance at cruising speed and rpm.
BB or SBC?
I’m currently running a 496 with a TKO600 5 speed, 0.82 5th gear and 3.08 rear gears.
At 70 mph I’ll be cruising at 2300 rpm in 5th gear.
Old Nov 14, 2024 | 02:07 PM
Redvette2's Avatar
Redvette2
My car has 3.08 gears (M20 trans/225 60 R15 tires) and it is just slightly too tall especially if on a steep hill or the engine is cold. Wonderful on the highway at 70 MPH and 2800 RPM's. If I was going to change the diff ratio, I would likely go to 3.36 but not worth it at this point. Car is just a weekend driver and fast enough for me.
https://spicerparts.com/calculators/...rpm-calculator
Old Nov 14, 2024 | 02:22 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
If you have the M21 close ratio transmission I wouldn’t go lower than a 3.70. The first gear ratio makes the car a little difficult to launch with the 3:55. If you have the M20 the 3.55 gear was an option because of the different gear ratio. I have the 3.70 in my 72 LT-1 and sometimes wish had the 4.11. Just my opinion.
Old Nov 14, 2024 | 02:37 PM
gccch's Avatar
gccch
I was just going through this with my newly acquired 70 BB. I have the M21 trans and 3.70 gears. My RPMs are half my MPH, so at 60 I'm doing 3000 RPM. I discussed going down to a 3.36 or even lower but was talked out of it by my Corvette shop owner as it is a desirable combination.
With yours being a LT-1, and a 70 at that, if it is original engine I would be inclined to match the rear end to original. It can handle the revs.!! And it should be driven to them often.
I'm going to keep the 3.70
Old Nov 14, 2024 | 05:23 PM
OldCarBum's Avatar
OldCarBum
You will find that your BB’s running temps will creep up to 220+ on the highway with the rpm’s at 3000.
Thats what was happening to me on warm days.
I always found myself at 55 mph and watching the temp gauge anytime I was on the highway.
55 mph on California highways is a perfect way to get rear ended.
With a BB or any SBC with some torque built into it you can easily get by with a 8.5 first gear ratio overall and unless you are drag racing you won’t loose much on take off.
My TKO has a 2.87 first gear ratio and coupled with my 3.08 rear gears puts me at an 8.8 first gear ratio.
You really have to look at the overall ratios of all gears with factoring in the rear gears, plus camshaft, torque, hp and where the engine produces the torque.
Old Nov 14, 2024 | 05:48 PM
GTR1999's Avatar
GTR1999
If you have a true 1970 LT1 car, you have a valuable car. 370 or 411 were common with them and if you have an M21 CR trans you may be better to just drive it.
However, if you want to drop the gear to 370 from 411 you have to see what you have inside first. Is it a GM 411 setup, it is an older Tom's 411 thick setup, is it the current Chinese knock off of Tom's 411 Thick??
Can it be done, yes. Cost depends on what you have, what you need and who does the work and the level of the build. That comes to between $800 and $3500 today.
Old Nov 15, 2024 | 12:25 AM
Michaelchop
My intention was to just drive it cruising around and car shows. The engine was rebuilt several years ago but all matching numbers and correct date codes for a CTU stamped engine. Big oil pan so no power steering, I do have a modern equivalent holley carb on it with the whats probably the original carb rebuilt in a box date coded to dec 69. The original exhaust manifolds were put back on after having side exhaust for a while. The only thing I'm not sure of is the rear end. When going over the codes the seller thinks it was from a 1973 corvette but I can't make out the numbers. I do know that it does have the 4.11s. They kept everything, I have the original water pump with the gaskets they scraped off. At least the more recent owners kept all the fuel receipts. I got all the trophies it won in car shows. It was originally sold in Canada and have alot of Canadian documentation. All the documents barely fit in the car when it was shipped. It's been fun learning this car.
Old Nov 15, 2024 | 01:37 PM
Barry's70LT1's Avatar
Barry's70LT1
If I may give my opinion.
My configuration was LT-1, Muncie M21, 3:70, with added GM side exhaust.
What I did not like was, (Which was great when I was young)
- High rpm while highway cruising, 3,000 rpm @ 70
- The 2:20 first gear of the M21
- Noise from the side exhaust at highway speeds
My solution was a Tremec TKO600 .64 od (Now)
- Highway, 70 mph, 2,000 rpm
- First gear 2:87
- 80% reduction in exhaust noise on highway.
- Substantial increase in fuel milage.
A 5-speed solves all your problems with one change. Major downside is the cost.
I have never regretted spending the money on the 5 speed. Installed in 2006.
Barry
Old Nov 15, 2024 | 03:11 PM
Tampa Jerry's Avatar
Tampa Jerry
Another vote for the 5 speed with a .62 overdrive. I installed it in my 66 also with a 4:11 rear. In overdrive I am at about 2250 RPMs at 70 MPH. I also have side pipes. Without the overdrive, I could not hear myself think at 70. The noise was way too much, especially over a prolonged period of time. My 68 has a M-21 and a 3:70 rear. As a kid I did not mind the high RPMs on the highway, now that I am older, I take the 66 with overdrive more frequently on the highway. Jerry
To Rear Gears
