350 CI Fuel Pump??
When removing my hard line from fuel pump up to fuel canister filter, fuel keep flowing out of the fuel line port on the pump. Does this mean I have mechanical pump is issue?? Last time I changed my hard lines I only remember fuel draining from the hard lines from the carb. Am I mistaken or do I have a problem with pump leaking fuel past a safety check valve? Sorry do know the workings of a mechanical fuel besides feeding fuel to carb based on engine operation/cam shaft rotation.
v/r
Mike P.
