Rear Suspension Question
Old Mar 12, 2025 | 11:16 AM
79Corvette!'s Avatar
79Corvette!
8th Gear
Default Rear Suspension Question
The rear end shimmys around when I let off the throttle. Car is low mileage but obviously very old. The differential or more likely the hubs have apparently moved around enough that the factory leaf spring clamps are missing. Some goon put hose clamps on them….. which remarkably are somewhat holding but the stack of leaves has shifted at each distal end for sure. The biscuits and rubber components do appear worn, obviously I need a new spring. Is there a specific spot to start with in terms of what to replace first? Or is this just “rebuild the rear suspension” scenario?
Old Mar 12, 2025 | 11:45 AM
69L88's Avatar
69L88
[QUOTE Or is this just “rebuild the rear suspension” scenario?[/QUOTE]
Short answer - yup.
Every rubber bushing needs to be replaced, period. Mileage makes no real difference when you’re dealing with 45 year old rubber.
Check the end play on the differential axles and consider replacing the rear wheel bearings.
Old Mar 12, 2025 | 12:40 PM
MelWff's Avatar
MelWff
You shouldn't need any clamps on the spring if the bolts on the center bracket were properly torqued and the separators haven't worn.
Unless the spring is showing signs of sagging buy the separators and rebuild the spring. Do not fully torque the 4 bolts in the center until the full weight of the car is on the spring.
Old Mar 12, 2025 | 01:15 PM
79Corvette!
8th Gear
Default Replies: Rear Suspension Questiom
Guys, thanks for your help. I can figure out how to check that end play on the axles during the pending deconstruction. My goal is to leave those axles in those hubs and avoid playing with those again. I think the suspension can be done with hubs on the axles. I like the idea of rebuilding the spring as a cheaper option. I saw those parts are available at Corvette Central. I think the spring separators are missing currently or I can’t see them. Good comment on spring bolt carriage too yet the spring itself doesn’t seem like my wobble, I bet it lo. Sounds like a piece at a time is not the right solution and I need to just pull it all out.
Old Mar 12, 2025 | 01:22 PM
GTR1999's Avatar
GTR1999
1978 inner axles, if original, were bad from day one. Regardless of low mileage, if you leave them in place you will be back at it in the future. Now, if you catch it in time and know what to look for, those axles may very well be saved but need treatment.
That is what I would do and I do this every day.
Old Mar 13, 2025 | 03:45 PM
Tampa Jerry's Avatar
Tampa Jerry
It could also be the trailing arm bushings or shims. A classic symptom is when you let off the gas, it feels like the rear of the car is shifting around. Jerry
Old Mar 16, 2025 | 07:17 PM
60 SHARK's Avatar
60 SHARK
Originally Posted by 79Corvette!
The rear end shimmys around when I let off the throttle. Car is low mileage but obviously very old. Is there a specific spot to start with in terms of what to replace first? Or is this just “rebuild the rear suspension” scenario?
Yea,, I believe its time to do it all. If you plan to drive the car out of your driveway, ya better get all that done ASAP. You won't regret doing it.
Old Mar 16, 2025 | 09:33 PM
thomas68's Avatar
thomas68
If you take the time to do bushings, be sure and use the OEM style rubber, not the urethane ones.
Old Mar 16, 2025 | 09:45 PM
gjohnson's Avatar
gjohnson
Shimmy Shimmy Coco Bop/TA bushings bad
Old Apr 2, 2025 | 10:17 AM
79Corvette!
8th Gear
Default Rear Suspension Question -continued
thanks guys for your input so far. Should I also order new subframe bushings for the rear cross-member when I dive into this rabbit hole? Second, I notice new rear leafs have retainer clamps around the leaves, while I have hose-clamps. The plastic spacers are in-place between the springs. Are there rods or pins through the leaves on each side up near the differential bracket or just those clamps? I do not see any.
Old Apr 2, 2025 | 10:37 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Mine did that when my strut rods were loose...check those bushings as well
Old Apr 2, 2025 | 04:54 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
The strut rod bushings handle 90% of the cornering load, and seem to be the first IRS part to wear out.
When T/A arm bushings dry rot, they crumble under the twisting, the rear end tends to shift around when you let off the gas, and steer the car.
OTOH the crossmember bushings are a much harder rubber, there is no rotation /movement involved, and even very old ones still seem to be OK.
And they are a real pain to get out. I would inspect those once apart and then decide.
The T/A bushings you can inspect on the car, use a large crowbar, and pry in the TA pocket. The arm should not move. At all. It can move 1/2" when bad.
Same with the strut rods. Inners and outers.
The inner axle stubs check their movement on the car with a dial or digital caliper. Check the wheel bearings with a dial indicator.
Old May 29, 2025 | 04:55 PM
79Corvette!
8th Gear
It’s definitely in curves and when I vary the throttle, let-off usually, that rear end moves and feels unpredictable. I was just into the axle stubs and they were tight.
QUOTE=leigh1322;1608695878]
The inner axle stubs check their movement on the car with a dial or digital caliper. Check the wheel bearings with a dial indicator.[/QUOTE]
ns
Old May 29, 2025 | 06:59 PM
Rescue Rogers
Check the bushings in the struts.......make sure the bolts are tight
Old May 29, 2025 | 10:01 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
To check either strut rod bushings or trailing arm bushings you can try two ways.
Look in the narrow gap to see the rubber and see if any cracks, crumbs, deterioration, etc.
Stick the end of a crowbar in there, and try to pry them both sideways and vertical. They should barely move ~1mm. When they are bad, they move a lot.
To Rear Suspension Question
