Getting ready for paint - having second thoughts
So with the engine out, I sent it into the paint shop, had the engine bay sprayed that color, and the rest of the car just primered. I did it this way with the intention of getting it all set up and running, and then driving it back to the shop when it was all done - that way I wouldn’t have to worry about scratching the car while working on it.
Well, the car is running and pretty much set to drive at this point, engine is back in the car and it’s time to bring it back in for paint…and in the 9 months or so since, I’ve started to have second thoughts. Everyone who has seen the engine bay is shocked when I tell them it’s grey, they all think it’s black (which is discouraging because I don’t want the car to appear black), and numerous people have been t vehemently trying to convince me go with a loud color like Amplify Orange. I initially thought AO was a little too modern for this car, but the idea is kind of growing on me. Regardless, I do like the idea of an orange, which makes it difficult.
My biggest hang up right now is the fact that I’ve already painted the engine bay Individual Gunmetal II. If I had gone with a satin black, I wouldn’t be here right now - I’d likely be changing the color. But because the engine bay is already grey, I feel like I now HAVE to go with this color. And in all honesty, I was a bit rushed into this at the time. We had to get the engine bay in for paint while the motor was out, I was pressed for time and initially WAS just going to do a satin black, but got convinced otherwise at the last second. I’m now regretting not going with my gut.
So what do you guys think? Should I stick with Gunmetal since it’s already in the engine bay? Or should I say screw it and have the bay not match the rest of the car?
I’m genuinely not looking for anyone to “say what I want to hear”, I just want real advice so I can be confident in the ultimate decision that I make.
Thanks!
Thanks!
I know it's easy for me to say but what's it going to take to remove the engine again... a few days worth of work, going to a semi gloss black can be done by yourself and not have to be sent back to the paint shop (frankly I think the semi glass black will look better regardless of color decision) this will also give you the time to decide on any color against that semi gloss black.
Thanks!
That said, I don’t plan to respray the bay. Taking everything out after I just put it al back in sounds like a nightmare!
I have seen a number of custom paint jobs where the body color and the engine bay color are the same and that looks nice. I wouldn't change it. It's not black. All you have to do is open the hood in better light conditions, like outdoors.
I overthink stuff all the time. I get it! I think you had the engine bay and body color right from the get go. Nice looking color and it will look sharp on this body style.
BMW Individual Gunmetal II
https://www.reddit.com/r/BMW/comment...ion/?captcha=1
Last edited by KS69Coupe; Mar 28, 2025 at 10:25 AM. Reason: added link to show the color
Most everything is off the car. The only thing remaining is the mirrors, and when we brought it in for primer, he sprayed right over it. So I’ll definitely be removing those before sending it back.
The other issue is that the heater box no longer fit inside the engine bay, so I decided to remove the heater core entirely and just not run heat for now (will likely do RetroAir next year or so), so I’m now left with a giant hole that I have to patch. I was going to have the painter spray a sheet of sheet metal and I’d rivet that in, but it’s not ideal.
Pics:
https://imgur.com/gallery/xsi5guc
Pics:
I agree, 100%..........that ain't black!
Gunmetal,Not black for sure. And the firewall needs a little TLC after the install.
Behind the booster needs a little sanding down since it got scratched up during the build. Haven't decided if the hood surround will be Gunmetal or the Crystal Red
That inner fender is Gunmetal. But between the splash guards and the shadows, it looks black.
Once the body is painted you’ll be able to tell it’s the same color though, especially in the sunlight.
I don’t think it’s bad at all though. The casual observer will only notice the LS and probably nothing else, I wouldn’t sweat it.
