Headlight issues
Old May 2, 2025 | 04:27 PM
Colin_72Vette's Avatar
Colin_72Vette
Default Headlight issues
Hey Everybody,
Got a headlight issue on my ‘72. Lights flip up but low beams don’t come on unless I hit the brights. Checked the dimmer, that wasn’t it. Installed a new switch. Still nothing. And now, when I activate the brights, they come on but after a few seconds, they start flickering. Finally, the foot pedal for the brights is sticking so if the lights are activated, the brights stay on. Any ideas what’s going on here?
Thanks in advance!
- Colin
Old May 2, 2025 | 05:39 PM
Mark.uli's Avatar
Mark.uli
Is your headlight switch a replacement unit? I didn't have non-functioning low beams but the high beam load would cause the internal temp breaker in the chinesium replacement headlight switch to go nuts.
You should probably trace your low beam circuit to figure out where the loss of continuity is or the grounding issue, and then either replace your new switch with the old one (as it's probably fine) or keep the new one and install a simple relay setup.
Old May 2, 2025 | 07:39 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Replacement headlight switches are junk. Put the original one back in. The foot switch is the high/ low switch. Sounds like a good place to start. Do you have power out of this switch for low beams? If yes start following the wire with a test light. Perhaps a bad connection at the firewall for instance.
Old May 2, 2025 | 09:42 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Just to make sure... these are standard, old-school incandescent bulbs and not LEDs?
To Headlight issues
