74 power troubleshooting
Old May 14, 2025 | 12:17 AM
Tylerdeanthomas's Avatar
Tylerdeanthomas
5th Gear
Default 74 power troubleshooting
Put in a new mini starter and now I don’t have power to my fuse block. Just wondering exactly where voltage goes after your starter, so I can trace it out at each connection. Went to a mini starter that doesn’t have the “R” terminal so I’m sure one of the wires that is no longer connected carries power to the next spot. I have 12v on the starter. I don’t just want to try each wire so wondering where the next step is from the starter and what color wire. I have two blue wires and a black wire that is no longer hooked up. Thanks!
Old May 14, 2025 | 02:18 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome
https://wordpress.keystonestatecorve...m/?page_id=118
Get the 1974 schematic and find and test your fusible links (thermal).
Old May 23, 2025 | 07:49 AM
Tylerdeanthomas
5th Gear
Default Solved
Figured I’d respond to this in case anyone else runs into this problem. Previous owner was using the “R” terminal as a junction point to bypass the seatbelt relay. I just spliced these three wires together and it returned power to my fuseblock and the entirety of the car.
To 74 power troubleshooting
