Courtesy Light won't turn off
Old May 25, 2025 | 09:36 AM
pauljalton's Avatar
pauljalton
4th Gear
Default Courtesy Light won't turn off
Hello,
I've searched previous posts and nothing seems to help. Came out of nowhere. I bought 2 new door switched- lights still stay on. This am I disconnected the door switches - lights stiill on. I disconnected the headlight pull switch thinking that was the problem- still stayed on. I took he courtesy light off the back wall under the deck- still on. Nothing else abnormal going on- headlights, tail lights fine etc. They only go off when I pull the fuse. Any ideas? thanks Paul in Ohio 1972 coupe 4 speed no courtesy light delay
Old May 25, 2025 | 10:10 AM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
What year is your Vette?
Old May 25, 2025 | 10:14 AM
pauljalton's Avatar
pauljalton
4th Gear
Old May 25, 2025 | 01:25 PM
hunt4cleanair's Avatar
hunt4cleanair
Did the vendor specify the year those switches were designed to operate? In the 70s, GM was adding ground devices and changing the number of terminals.
Here's a page from the NCRS 1973-74 that explains some of this in the context of 1972 production. Hope this helps!
File Type: pdf
Old May 25, 2025 | 01:48 PM
carriljc's Avatar
carriljc
pauljalton
What did you pull? What does this mean?
"I disconnected the headlight pull switch thinking that was the problem- still stayed on. I took he courtesy light off the back wall under the deck- still on."
I am not trying to offend you--- so this is just a question. Did you realize that turning the headlight **** will actuate and/or adjust dimness of the courtesy lamps? Did you turn the ****?
Old May 25, 2025 | 02:38 PM
TKX 5-SPEED C3
Originally Posted by carriljc
pauljaltonDid you realize that turning the headlight **** will actuate and/or adjust dimness of the courtesy lamps? Did you turn the ****?
It's a mistake that anyone can make if they're not familiar with these cars.
Old May 26, 2025 | 12:12 AM
7T1vette's Avatar
7T1vette
Just exercise the door switch with your finger. If it doesn't go out when you push it, either the switch is defective, the switch is wired improperly, or there is no chassis ground connected to the switch wire.
If it goes out when you push it, but doesn't when you close the door, you are missing the little cushion that the plunger is supposed to hit when the door closes...so the switch plunger is never moved far enough to actuate.
Old May 27, 2025 | 11:01 AM
pauljalton's Avatar
pauljalton
4th Gear
No offense taken and I appreciate the efforts to help. I've owned this one for about 20 years- done most of the work myself. I restored the dash and interior long ago and I know my way around the car pretty good
Some Clarification:
Both door switches are new with the signal wire male connector- correct for 72. I took them both out, - making sure that the single wire is not grounded to the car. This would take any issue with the door switches out of play I believe
I disconnected the headlight switch briefly thinking that the rheostat? that you rotate to turn to dim the instrument lights and turn on the courtesy light is not the problem - thinking it was maybe stuck in the on position
I will try to trace and isolate the courtesy lights wiring thinking that maybe they are grounding out somewhere?
Old May 27, 2025 | 12:04 PM
ZIOGEO's Avatar
ZIOGEO
If you removed the door switches and the courtesy lights stay lit then you likely have a short to ground somewhere. Did you change any of the courtesy light sockets or any other work on the electrical system recently?
Years ago I had a similar problem and traced it back to a pinched wire under the passenger seat (old Mustang) that kept the seatbelt warning lit. Drove me nuts for weeks
Old May 27, 2025 | 02:38 PM
7T1vette's Avatar
7T1vette
The door jamb switches pass electrical ground to the lights (rather than power). Still don't know if the switches work properly when they are MANUALLY depressed.....
Old May 28, 2025 | 04:59 AM
Eliredandblack's Avatar
Eliredandblack
Remove / unscrew each of the u dr dash courtesy light bulb holders from the car (isolate them from any metal). I had bought new bulb holders and one was bad, so the bulb was always on, no matter if the door was closed. You just love the restoration parts, I ended up buying a new courtesy light for holder.
Old May 28, 2025 | 06:16 AM
forman's Avatar
forman
Is there one under the hood in the engine bay back near the fire wall mine has one .. if the hood is open or off it would keep it on
Old May 28, 2025 | 08:55 AM
7T1vette's Avatar
7T1vette
That would keep the hood light on....
Old May 28, 2025 | 12:57 PM
forman's Avatar
forman
On my 70 it’s on the same loop if the hoods is open the inside lights stay on
To Courtesy Light won't turn off
