crazy gas gauge
Old Jun 21, 2025 | 01:17 AM
triploak's Avatar
triploak
Navigator
Default crazy gas gauge
I filled my gas tank and the needle shows wayyy past full. Drove for 1/2 hour and needle swings between 1/2 tank and full tank. Bad sending unit??
Old Jun 21, 2025 | 02:12 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Sending unit is easy to check with an ohm meter. But the swinging sounds like a bad guage.
The connector for the sending unit is in the left hand side quarter panel. Unplug it. Connect your ohm meter across it. Have your helper raise and lower the float arm using a bent coat-hanger through the filler hole. It's a zero to 90 ohm sender. Pretty standard fare.
Old Jun 21, 2025 | 09:56 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...one of the easiest & cheapest things to do for this is to check and clean the black ground wire going to the frame back in the left rear corner, at least on a '68. This fixed my swinging gas gauge instantly.
Old Jun 21, 2025 | 11:00 AM
triploak's Avatar
triploak
Navigator
thank you for letting me know!
Old Jun 21, 2025 | 01:15 PM
7T1vette's Avatar
7T1vette
Most likely bad electrical connection (corrosion) on terminals under rear of car. Check the ground connection first. Remove, de-rust, wipe clean, reassemble and test the result. If that fixes it, coat the connection with sealant that will keep water/air out.
Old Feb 23, 2026 | 11:38 AM
FLX C7's Avatar
FLX C7
I had this problem 2 years ago, shortly after buying my 2014 Z51. Techron treatment did the trick.....for a while. When it failed again Techron didn't work. The right fuel tank gauge failed. My extended warranty paid the $3000 bill to put in the new sensor which was mechanically stuck. This past November it happened again. This time the left side sensor failed and the left side fuel pump had a low pressure signal. Once again my warranty paid the $3200 bill. So your fix may be costly. Since most of the cost is labor to drop the whole rear sub-assembly, change both sides at once! Good luck.
Ken
Old Feb 23, 2026 | 01:42 PM
socal_tom's Avatar
socal_tom
Yes agreed sounds like a bad ground
Old Feb 25, 2026 | 04:21 PM
spdrcr29's Avatar
spdrcr29
Here's a video from Willcox Corvette where they do testing for different fuel gauge operation scenarios. Maybe this will point you in the right direction?
Old Mar 30, 2026 | 08:41 PM
GreenVette9's Avatar
GreenVette9
Didn't. Mean to post here. Sorry.
To crazy gas gauge
