Battery power issues
Old Jun 24, 2025 | 06:51 PM
Helibudi's Avatar
Helibudi
Cruising
Default Battery power issues
I know there may already be a thread about this somewhere, but couldn’t find one, hope someone may have some insight into what I going on, to start about a month ago I pulled the battery and jack out and laid some fiberglass in the bottom of the compartments and painted them, installed all new hardware and hold downs, new doors and latches on storage compartments, have driven the car 3 times with the last being on 6/12, got home and backed into garage, went back out later to hook up battery tender, noticed that the curtesy lights were not on,turned the key no dash lights came on as if I had no power, left for vacation on 6/13, got back on the weekend and went out yesterday 6/23 to start testing and everything is working now, I’m a little confused, any suggestions or has anyone else seen this issue? Forgot to mention I’m working on a 74 Stingray
Old Jun 24, 2025 | 07:35 PM
OldCarBum's Avatar
OldCarBum
Check the positive and negative cable connections and make sure they are clean and tight.
The cable can be badly corroded under the insulation.
They can look good on the outside but corroded through on the inside.
You can check them with a meter but if they are the originals, they probably need to be replaced.
Old Jun 26, 2025 | 06:59 PM
Helibudi's Avatar
Helibudi
Cruising
Thanks OldCarBum, I’ll test them this weekend and see what happens
Old Jun 27, 2025 | 07:33 AM
sphil's Avatar
sphil
On my 76 the stubby ground cable near the starter was corroded as carbum described. Local auto parts made a new one, just make sure they crimp the terminals in the same orientation as the original.
Old Jul 4, 2025 | 11:05 AM
Helibudi's Avatar
Helibudi
Cruising
Thanks guys for the replies, due to A/C issues this past week I haven’t had time to look at the car till today ( 7/4/25) I did find the positive battery cable a little loose at battery, haven’t found any thing else yet,will see what happens next time I take it out.
Old Jul 5, 2025 | 08:12 AM
7T1vette's Avatar
7T1vette
The larger issue may be the negative (ground) cable connection under the battery box to the frame. That may need to be removed, cleaned up, and re-done in order to restore solid electrical ground. Also, those old cables may be deteriorating INSIDE the insulation at the terminal junctions.
Old Jul 10, 2025 | 07:38 PM
Helibudi's Avatar
Helibudi
Cruising
Thanks 7T1, that connection was cleaned and reconnected when I cleaned,fiberglassed, and painted the storage compartments, have also double checked it for tightness, I think I will order new cables and replace them as oldcarbum recommended as I don’t know the age of the ones in the car.
To Battery power issues
