Won't start, won't crank, please help.
The push button start has 2 posts. 1 wire goes to the big terminal on the starter. The second wire goes to the s terminal on the starter. Ground to ground, 12v to 12v. Test light and voltmeter give 12 volts and a solid ground.
I'm starting to wonder if the solenoid is damaged or no good.
Can you post some photos?
Forgive me, I misspoke. It's been a long few weeks, and no one can seem to figure out the problem with this damn car. As you can see, the big terminal on the starter is getting 12v power. The s terminal does not light up for a ground. I understand the wiring looks messy, but 2 of those wires are not usually there as they are still attached for the push button start.
It looks like a black wire is attached to the S terminal, and another to the R terminal. And three wires to the main lug.
If the S wire and one of the main lug wires go through the add-on switch, and the OP still has a points ignition, I really can't explain what's wrong.
And without that photo, what refutes that the S terminal isn't grounded? Grounding the S terminal is 100% consistent with the symptoms.
Bridging the main lug to the solenoid output terminal cranks the starter (badly). But so should applying voltage to the S terminal, unless the solenoid doesn't work, or the S terminal is grounded, just like the OP stated!
OP: Can you measure the voltage at your bypass switch? I know you say it's 12V, but it looks like you just have a light up test probe. With the switch depressed, you should have 12V on both sides. If it drops, at least we'd know the current is going somewhere, even if it isn't actuating the solenoid.
And since half of the solenoid diagrams have S and R reversed, I'd make 100% certain you read the markings on the solenoid, and don't rely on a diagram. I can't see the markings in your photos.
Last edited by Bikespace; Aug 3, 2025 at 06:00 PM. Reason: Changed starter diagram
Before you put a forth starter in there, can you try bench testing one?
Here's a photo of when I did this (and a bonus photo of a mini starter on my LS6, using the same harness setup, and a lithium battery).
Just as you have it, It only needs battery power and ground, and switched 12V to the S terminal.
Do you hear any sound at all? Even if the mesh is way off, and the starter can't spin, the solenoid should still click.
I am at a loss to explain why your starter isn't working.
