Won't start, won't crank, please help.
Old Aug 4, 2025 | 05:33 PM
  #41
HeadsU.P.'s Avatar
HeadsU.P.
Dark,
Basically, all your troubles began when you switched from a Breaker-Point IGN System to a HEI IGN system?
The solenoid terminal post marked "R" is involved with the older models, but not the newer "75? 76? with HEI.
And in the photo, I still don't see an extra GRD wire, cable or strap to the frame.
And, does your model year need the forward bracket starter to block also? They are usually missing.
Wherever you did buy starters, stop.
Old Aug 4, 2025 | 08:19 PM
  #42
fstntq's Avatar
fstntq
Originally Posted by darktheist69
Update... Went and got another switch, checked terminals after hook up. 12v and ground to the switch, and nothing.
You shouldn't measure ground at the switch. 12V in and the out goes to the "S" terminal of the starter. All it is, is a fancy bump starter.
